h22 in a crx hood clearence ?'s
Old Feb 10, 2006 | 08:03 AM
fastsaab's Avatar
Default h22 in a crx hood clearence ?'s
i am going to put an h22 in a crx next winter. the car is a 1990 si, i understand most of the things required to do it. i want to use the hasport mounts and i read you cant use the stock hood because of valve cover clearance. would it be possible to use a zc cf hood?
http://www.passwordjdm.com/pro...D=147
thanks, michael
Old Feb 10, 2006 | 08:49 AM
fastsaab's Avatar
Default Re: h22 in a crx hood clearence ?'s (fastsaab)
bump
Old Feb 10, 2006 | 08:52 AM
beyondspexj's Avatar
one person you can definetly ask is a kat on here that goes by explicedperformance or something like that. go to the search fourm, and search for h22 mounts and his screen name should pop up as one of the authors. he has his own custom made mounts for his h22 in is ef and you can get a set from him as well. ill try to find the name
Old Feb 10, 2006 | 08:54 AM
ok his screen name on here is ExplicitSpeed360. send him a pm and see what he says. also check out his web site. http://www.ExplicitSpeedPerformance.net
Old Feb 12, 2006 | 09:37 AM
fastsaab's Avatar
Default Re: (beyondspecs_jamar)
bump
Old Feb 13, 2006 | 04:43 AM
higgunscrx's Avatar
the stock hood can be used with the hasport mounts, i dunno where you got your info from but.... if you want verification ask bian on these boards he works for hasport i think his screen name is "brian g"
Old Feb 13, 2006 | 07:43 AM
fastsaab's Avatar
Sport compact (working directly with Hasport) did an issue on swapping an h22 and they specificly said the inner stucture on the hood would NOT clear the valve cover. They said a gutted stock hood would work. Thanks for a step in the right direction though.
Old Feb 13, 2006 | 07:46 AM
Jonknee's Avatar
any chix wanna chat c2c 15/f/alabama
Old Feb 13, 2006 | 08:22 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: h22 in a crx hood clearence ?'s (efnewb91)
with my kits just about 1/2" of hood clearance between the highest point on the H22 valve cover to the stock usdm hood. Ground clearance is 3 1/2" on a 2" drop. Please check out the site for more H22 EF info.-John
Modified by ExplicitSpeed360 at 9:42 AM 2/13/2006
Old Feb 13, 2006 | 11:30 AM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnewb91 &raquo;</TD></TR><TR><TD CLASS="quote">any chix wanna chat c2c 15/f/alabama </TD></TR></TABLE>
el oh el
Old Feb 13, 2006 | 02:26 PM
91B16HF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnewb91 &raquo;</TD></TR><TR><TD CLASS="quote">any chix wanna chat c2c 15/f/alabama </TD></TR></TABLE>WTF?
Old May 23, 2006 | 11:38 AM
9WON4's Avatar
this is more so a problem with the H2B conversion
discuss solutions in practice not theory please
thanks
Old Jun 15, 2006 | 08:18 AM
djnikko's Avatar
Default Re: h22 in a crx hood clearence ?'s (kidkanedtx)
so can we conclude a stock hood with the webbing/skelton cut out right will fit using the hasport mounts?
cheers
Old Jun 15, 2006 | 08:47 AM
2lude4u's Avatar
Default Re: h22 in a crx hood clearence ?'s (djnikko)
No, you saw my post in the hybrid forum. https://honda-tech.com/zerothread?id=1646586
The Hasport kit will not clear the USDM OEM hood unless you actually cut a hole in the hood or space it up an inch in the rear & 1/4" up front.
It won't even clear a VIS SiR style (USDM fitment) CF hood, almost does though. Apparently it will clear the fiberimages Sir style CF hood (no skeleton underneath) & maybe some other brands. It might clear a JDM SiR metal hood, but probably would require a little cutting of the skeleton or spacing it up a little.
Old Jun 15, 2006 | 09:12 AM
jlicrx's Avatar
read this:
http://www.hasport.com/Tech/installs/efh1.pdf
CRXBart's Avatar
Default Re: h22 in a crx hood clearence ?'s (ExplicitSpeed360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">with my kits just about 1/2" of hood clearance between the highest point on the H22 valve cover to the stock usdm hood. Ground clearance is 3 1/2" on a 2" drop. Please check out the site for more H22 EF info.-John
Modified by ExplicitSpeed360 at 9:42 AM 2/13/2006</TD></TR></TABLE>
I typically hate on H22 swaps in a crx, but I just checked out you site, and I applaude your work. If I was going to do an H22 swap I would use your mounts, your engine placement looks great, I just wonder how your axle angle is. I would still never do a h22 swap in a crx, but your kit looks great, and the price is right.
Old Jun 15, 2006 | 10:29 AM
Banned.
Default Re: h22 in a crx hood clearence ?'s (CRXBart)
Here is an axle alignment picture...perfecto...
Our EF H22A Kit:
Old Jun 15, 2006 | 10:34 AM
CRXBart's Avatar
Good work, you could even come a little lower with it. Thats at 2" drop too right?
edit: BTW you should put that pic on your site.
Old Jun 15, 2006 | 10:37 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">Good work, you could even come a little lower with it. Thats at 2" drop too right?</TD></TR></TABLE>
2.5" would make them almost perfect it looks like.
Old Jun 15, 2006 | 10:54 AM
Banned.
Default Re: h22 in a crx hood clearence ?'s (ludesrv)
Yes a 2" drop...like butta...
Yeah I just found the pic and its on my site under the how to...
djnikko
Feb 21, 2010 07:32 AM
JcasT
Aug 30, 2009 04:04 PM
djnikko
Sep 26, 2006 09:32 AM
djnikko
Aug 11, 2005 06:06 AM
1700anddroping
Jul 8, 2004 05:51 PM
