4 channel amp that 2 two rca inputs, my deck only has 1 rca output
I want to get a 4 channel amp such as http://www.walmart.com/catalog...41642 and hooked up four speaks to it. I was looking at the picture and it shows it has two rca outputs. Should I just get an 2-4 wire RCA splitter? Do current amplifiers have cross-overs built in them or should I look to get an cross over that can split the rcas?
Nick
Nick
Yes, you can split the RCA's with a pair of "Y-Adapters", and it'll work but you won't have the ability to fade front to back (if that matters).
And that amp does have a high pass filter so you don't need anything else.
some 4 channel amplifiers have a switch on it where you can feed the signal from the front channel # 1 and 2 rca inputs into channels 3 and 4. if it doesn't just use Y cords like what was previously mentioned.
pretty much all amplifiers have crossover built into them nowadays.
ilikeric3
Audio / Security / Video
30
Sep 2, 2006 02:21 PM
Jonathan_ED3
11
Jul 9, 2003 10:33 AM
