holes in the hatch
So i just took of the stock GS-R wing and bout to put on the the ITR wing, but there is that one hole to the right for the brake light and one extra to the left, what do i do about these holes? buy a plug or what? also, its ITR replica so i need bolts to go in from the other side of the hatch since they are not built into the spoiler, what do i use, any normal 10 mm bolt, but how big in length? anyways, thanks though
the one on the left hand side should be attached to your stock wing. it is a white plastic plug.
Go to Home depot or Lowes or ace hardware and get 7/8" and I think 10mm size nylon plugs. I only found white but they do have black but they were sold out.
If you wanna be **** about it. take it to a body shop and have them weld the holes shut and paint the hatch.
also the stock wing bolts are just studs. so you can buy them or get bolts. jsut take the nut to the store and match the nut.
Eg_TypeR
Paint and Body
Feb 25, 2008 05:22 PM
