noise when clutch is disengaged?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 »</TD></TR><TR><TD CLASS="quote">
have fun</TD></TR></TABLE>
Yeah....a WHOLE bunch of fun that will be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin »</TD></TR><TR><TD CLASS="quote">
Yeah....a WHOLE bunch of fun that will be. </TD></TR></TABLE>
pssssssttt sucks for him sucks for him
how long do i have b4 it goes bad? its been doing this for a few months now. Im about to put my jdm 22 in with m2b4 tranny so i dont need 2 replace now
just when i go to use the f22 again
edit: i dont knwo much about the throw out bearing but what effect does it going bad have on the tranny? could it be a reason why its getting tuff to put it in gears when the cars cold?
edit: "The classic symptom of a worn throw-out bearing is a whirring or growling sound when applying the clutch pedal, which goes away when releasing the pedal."
i found that on the net. in my case its opposite i have a noise when the pedal is not pressed in and when i press it in it goes away.
Modified by M2B4 at 8:18 PM 2/9/2006
just when i go to use the f22 againedit: i dont knwo much about the throw out bearing but what effect does it going bad have on the tranny? could it be a reason why its getting tuff to put it in gears when the cars cold?
everytime its gone bad..its noise right as ur pushing it in..then noise when the clutch is out until your car is so loud you cant hear it....
if your swapping ur engine soon dont worry about it until then...when you do your swap and do all your sela replacement, etc... get a good throwout bearing...the aftermarket ones have plastic in em and suck...i always use the oem part for that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 »</TD></TR><TR><TD CLASS="quote">when you do your swap and do all your sela replacement, etc... get a good throwout bearing...</TD></TR></TABLE>
why would i need to get a new throw out bearing if im replacing the whole transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">maybe because the throwout bearing is not part of the transmission?</TD></TR></TABLE>
the throw out bearing is inside the tranny case how could it not be part of the transmission?
"If the noise goes away when you lightly rest your foot on the clutch then the problem is a bad release arm bushing" i found this on the net also? could this be it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 »</TD></TR><TR><TD CLASS="quote">everytime its gone bad..its noise right as ur pushing it in..then noise when the clutch is out until your car is so loud you cant hear it....
if your swapping ur engine soon dont worry about it until then...when you do your swap and do all your sela replacement, etc... get a good throwout bearing...the aftermarket ones have plastic in em and suck...i always use the oem part for that</TD></TR></TABLE> Yes aftermarket one SUCK BALL SACK SON, im using a junk *** act tob and i get to pull my tranns out this spring break and putting a oem tob in+rear main, oil pan seal, flywheel resurface, exedy organic. clutch chatter is owning me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote"> Yes aftermarket one SUCK BALL SACK SON, im using a junk *** act tob and i get to pull my tranns out this spring break and putting a oem tob in+rear main, oil pan seal, flywheel resurface, exedy organic. clutch chatter is owning me</TD></TR></TABLE>
word stevo matt and john both had the same prob with their clutch masters bearings..so when the exedy came i ordered a honda bearing when i saw it was that pos plastic ****...their strife really helped me out...we all know how taking out trannies is a day of fun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">
the throw out bearing is inside the tranny case how could it not be part of the transmission? </TD></TR></TABLE>
because it is not in the tranny case...how can you have M2B4 as your sn and be so uneducated on transmissions??
"If the noise goes away when you lightly rest your foot on the clutch then the problem is a bad release arm bushing" i found this on the net also? could this be it?</TD></TR></TABLE>
its not really a bushing on the release arm anyway...stop looking on v8 sites....that noise is comming from a spinning piece (the throwout bearing) when you swap ur engine...clean and grease up that release arm pivot (it looks like a ball and socket joint (like a human shoulder and arm))
i know that i typed it wrong my tranny comes with the clutch and clutch accesories and all thats what i meants on why i dont need to replace it
thx for the advice
thx for the advice
thx for the advice</TD></TR></TABLE>
yea you do smartypants...unless you wanna go back in there once you finish and find out oops! i guess this used bearing/ or plastic aftermarket one sucks
thanks for advising me on a situation ive seen and fixed on 3 separate h22 swaps
ya, my tob that came with my exedy is going bad too...and i prbly had it in for about 10,000 miles or less. Does any aftermarket company make one that is metal or is it just OEM that does?
Ive got a bad chatter on my 3rd gen when I push the clutch in... Im sure its not the throw out bearing though...
I kinda like the noise.. It sounds like 2 aluminum disks chattering against one another....
It must be because of the VTEC...
Was my post helpful?
Sorry to bring this thread back but i am having a similar problem. I bought my with a fairly new clutch. I am sure is aftermarket because it doesnt seem like a stock clutch.the car doesnt go in gear when its on and hardly goes if i push it in with pressure. When the car is off there is no problem at all going into gears. Once i get it into gear there is that " clutch Chatter" but once i give it gas its fine.
im confused i jus starting having this problem too i swapped motors but used the same clutch from my other tranny but with a new oem tob.....what exactly is going on with my car??? if only tob makes the noise mines is oem about 2 months old????
what from i've read, this problem is the "input shaft bearing." i'm not sure if this is the technical name for it but i know that it's not the throwout bearing and is a bitch to get to because it's somewhere in the tranny.
i have the same problem. i've been riding with it for about 30,000 miles. the car still works but i have a very inconsistent clutch engagement. it engages at different spots whenever it wants to - i think it may be a loose spring or slave cylinder. on my car, it's wicked hard to get it into first.
damn the tranny problems
yes i have been driving with it for about 6000 miles. and when its cold its wicked hard to get into first also. but i got new tranny when i do my swap so i dont care ne more lol
