2ND BLOCK GONE in 2 weeks!!! help
Old Feb 9, 2006 | 05:43 PM
elecgenius's Avatar
Default 2ND BLOCK GONE in 2 weeks!!! help
i went through a dohc zc block last week for not checking my oil,,,,dammit. i swapped in a d16a1 after milling my head and changing every single gasket, pressure leak testing it,,,, so on,,, and the friggin engine started knocking on me recently!!!!! the car ran perfectly. the only thing that went wrong is i had to modify the front motor mount, re tap the transmission for some extra holes, shave down the interior of the trans, get the pulley set (crank, cams) but damn thing is knocking!!! my question is can i swap a d15 or d16 bottom. i got 2000 on me right now but the engine i want is gonna take me longer build. its my only car since my formula;s head gasket took a ****. and i just bought the whole front end sir conversion for it. sould i just buy a little bucket for 800 bucks and wait or swap a zc bottom. also, a friend of mine has the sohc zc for 250 complete swap,, should i swap it as a whole or can i swap the bottom end.
Old Feb 9, 2006 | 05:49 PM
ludesrv's Avatar
D15 or D16 or SOHC ZC bottom ends won't fit with that head. Only DOHC ZC. Different bolt pattern.
Good luck man.
Old Feb 9, 2006 | 06:26 PM
elecgenius's Avatar
Default Re: (ludesrv)
THANKS i got my friend to sell me his complete soch zc swap for 200. thanks again man, problem solved(i appreciate it, especially since i was thinking of taking the sohc apart to swap bottoms)lol
Old Feb 9, 2006 | 06:28 PM
Pee Wee's Avatar
Default Re: (elecgenius)
change your oil this time please
Old Feb 9, 2006 | 06:35 PM
elecgenius's Avatar
Default Re: (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">change your oil this time please </TD></TR></TABLE>
lmao /^
hehe, i did the whole tune up, i still got to check the crank pulley, it might be loose or the pin is probably worn (the pin is from a d16a1 "old" versus my old zc from a newer rover in europe) it doesnt seem as internal knocking. another thing is i tried the lucas fuel additive and hours later it started knocking(?)
Old Feb 9, 2006 | 06:36 PM
Pee Wee's Avatar
thats why i only put fuel in my fuel tank
daredeezy619
10
Jun 26, 2009 12:35 AM
B18C1_CRX
Jul 10, 2006 12:09 AM
pdiddyparsons
Oct 25, 2002 10:41 PM
maximedx
15
Jan 30, 2002 12:41 PM
Speedz
Sep 23, 2001 10:02 AM
