VIN location on USDM H22a4?
Old Feb 9, 2006 | 03:49 PM
Propulsion's Avatar
Default VIN location on USDM H22a4?
I am trying to buy a motor and I want to make sure it's legit.
The motor is a H22a4 meaning that it's usdm.
The head is stamped 96, meaning that it was in a 97 car I think?
The seller couldn't find the VIN plate. Is it in the same place as b-series motors? on the bottom of the front of the block?
Old Feb 9, 2006 | 04:56 PM
BB6racer's Avatar
i just saw mine the other day changing the oil. its under the slave cylinder.
Old Feb 9, 2006 | 05:04 PM
Propulsion's Avatar
Default Re: (BB6racer)
what is the slave cylinder?
Any place on the Longblock itself?
Old Feb 9, 2006 | 06:57 PM
SteveoBA8's Avatar
Default Re: (SilverCIVIC96)
lol, the Slave cylinder is part of the hydrolic clutch system, bolted in the front of the block with 2 10mm bolts. Follow the clutch hard line on the transmission. The slave is right by the front engine mount.
Old Feb 9, 2006 | 11:11 PM
Propulsion's Avatar
Default Re: (SteveoBA8)
so the vin is on the engine block itself, not on the tranny right?
Old Feb 10, 2006 | 04:11 PM
Propulsion's Avatar
anyone?
Old Feb 10, 2006 | 04:23 PM
soundbomber's Avatar
as far as i know, only the tranny gets stamped with a vin tag, the block gets a serial number under the engine code iirc
Old Feb 10, 2006 | 06:44 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
i have a 2000 H22A4 and it has a VIN plate like a car rivited onto the back of the block just below the oil filter. I'll post a pic tomorrow.
Old Feb 11, 2006 | 11:27 AM
Propulsion's Avatar
Default Re: (cb7-R)
yeah, I'd really appreciate that.
ANother question. What can I look for on a block to tell if it's a SH of Base? Will carfax tell me if I pull the VIN? Is there any visual cues to look for?
Old Feb 11, 2006 | 11:58 AM
SteveoBA8's Avatar
Sh and base have different oil filter locations, base is normal hondy above oil pressure sending unit and SH is more to the drivers side. Also the Sh block has threads for the 4 bolts that bolts the atts box to the back of the block
dapdabbin
Feb 21, 2013 03:02 PM
MarkCayabyab
Oct 10, 2012 07:51 AM
EG6_978
Jan 5, 2010 10:39 AM
SMZ GSR
Nov 8, 2008 12:29 AM
dynamo
Jun 26, 2005 11:30 AM
