Need some wiring help
Old Feb 9, 2006 | 02:07 PM
Broke EF's Avatar
Default Need some wiring help
Ok guys I have a 90 STD Hatch and just did a 97 GSR swap converted to OBD1. I also have a 91 CRX dash and gauge cluster. The car is all fine but the cluster is not working, no gauges read at all (except the speedo) and it dosent light up. I discoverd the CRX dash wiring is different than the Civic so the Civic dash harness is in there now and still nothin. At one point the temp gauge moved and the check engine light worked but that didnt last long. Also the turn signals arent working but the hazards do. Any help at all would be greatly apreciated.
Thanks,
Sean
Old Feb 9, 2006 | 04:47 PM
Broke EF's Avatar
Default Re: Need some wiring help (Broke EF)
Bump. Come on someone has to know somethin I need to get this worked out
Sean
Old Feb 9, 2006 | 06:36 PM
Vtakkk's Avatar
Why dont you just go to a junkyard ? ?
Old Feb 9, 2006 | 10:00 PM
Broke EF's Avatar
Default Re: Need some wiring help (Stupid EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stupid EF &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you just go to a junkyard ? ?</TD></TR></TABLE>
What am I gonna do at a junkyard? I dont see how this is gonna help.
Sean
Old Feb 10, 2006 | 12:42 AM
99teggsr's Avatar
the junkyard will have the correct dash harness, one from a 90 STD Hatch
Old Feb 10, 2006 | 02:21 AM
I heart My EF Sedan's Avatar
Default Re: Need some wiring help (99teggsr)
either that or do the wiring yourself.. do a search for "gauge cluster" in this EF section and you'll find some wiring diagrams.... basically you might have to do some depinning and maybe some extending of the wires...
Old Feb 10, 2006 | 07:14 AM
Broke EF's Avatar
I have the 90 harness and the 91 CRX Si harness. I tried finding the wiring but didnt find much. As of last night it lights up the brights indicator lights up as well as the turnsignal indicators. The gas gauge and temp gauge MAY be working as well but I couldnt let the car run to warm it up cause it was to late and gas I duno Ill have to drive it for a while to see I guess. I still have to turnsignals no brake light no tach no oil light no check engine (this is the one I need) Im almost ready to give up but I need the check engine light.
Sean
mtflyboy25
Aug 24, 2011 06:00 AM
91Hatcher
Oct 24, 2008 09:54 PM
Rocky's_CRX
Jan 30, 2006 03:19 PM
xCIVICx
May 4, 2005 07:24 PM
CilveReX
Mar 23, 2004 11:05 PM
