help: idle is too low. below 1k and just did auto - manual
Old Feb 9, 2006 | 01:31 PM
owned!'s Avatar
Default help: idle is too low. below 1k and just did auto - manual
alright, i ran into a little problem with i was changing my gas pedal. the automatic throttle cable would not work with my manual pedal, so i had to leave my automatic gas pedal on. so the pedal is currently sitting higer then what its suppose to be.
anyways, my cable is adjust to the max setting and i can no longer adjust the cable.
my throttle screw is also max out so there is nothing i can do to adjust the idle.
would changing my throttle cable help on this? or is the cable the same for auto and manual?
edit: When i turn the AC on, my idle goes to almost 0. and i have to REV to prevent it from shutting down.
Modified by owned! at 3:20 PM 2/9/2006
Old Feb 9, 2006 | 01:42 PM
Azn Kenny's Avatar
Your idle is below 1k?
That is normal, LS's usually idle at 750 rpms.
Old Feb 9, 2006 | 01:45 PM
95TegSE's Avatar
Default Re: help: idle is too low. below 1k and just did auto - manual (owned!)
Yeah stock idle is 750 +/- 50 rpms
ecks_fourttwo's Avatar
Default Re: (LSntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">Yeah stock idle is 750 +/- 50 rpms</TD></TR></TABLE>
mines stays close 800
Old Feb 9, 2006 | 02:28 PM
SilverDc2's Avatar
Default Re: help: idle is too low. below 1k and just did auto - manual (95TegSE)
If you would have researched, you dont need to replaced your gas pedal or cable, i did a auto to man.... leave it alone your fine.
It was probably messed up before and you fixed it.
asocallocal
Sep 23, 2010 06:20 PM
jorge59la
Apr 8, 2007 10:00 AM
emooheo
Mar 23, 2007 02:34 PM
korndog
Sep 14, 2004 05:59 AM
blah13
Jul 5, 2003 11:22 AM
