eg and integra brake question
i have a 94 civic cx. i'm planning to change my front rotors and i want to use bigger ones but dont want to pay a lot for big brake kits. im planning to use the rotors off integras, are the gsr rotors bigger than the ls rotors? i know i need to change some stuff to make this swap work so what else do i need off the integra gsr/ls to get this. thanks.
i did this swap recently, do yourself a favor and get new rotors/pads/lines at the same time. if you plan on getting a camber kit i'd do it at this time too..but that's on you. And all the integras are the same size..besides the type R. Its a fairly easy swap, but its best to do all this stuff at the same time...then go get it aligned.
mainly i need integra's master cylinder, propotional valve, calipers, brake lines, and that metal piece that holds the calipers(what are those called).
i'm planning to junkyard these crap i name up above, as for the rotors, pads i will buy new. is this all correct?
another quick question, would integra sway bars fit on 94 civic hatch cx??
Integra rear sway bars will not go on a 94 CX because the rear LCAs don't have the mounting points for it.
for your brakes, did you totally read this? https://honda-tech.com/zerothread?id=1513752
I wrote that, if its unclear, please PM me so i can make it easier to understand.
curiousgpnoy
Jan 11, 2004 04:46 PM
JdmVetteEater
13
Mar 15, 2003 06:48 PM
