Where is the transmission fluid???
Old Feb 9, 2006 | 12:24 PM
phatsprinter's Avatar
Default Where is the transmission fluid???
My 1994 transmission it really ruff!! what is new huh? But where is the fluid located at so i can put some lube in there. thanks
Old Feb 9, 2006 | 03:33 PM
Chiovnidca's Avatar
Default Re: Where is the transmission fluid??? (phatsprinter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatsprinter &raquo;</TD></TR><TR><TD CLASS="quote">My 1994 transmission it really ruff!! what is new huh? But where is the fluid located at so i can put some lube in there. thanks</TD></TR></TABLE>
On the front of the transmission to the left of the battery.
Old Feb 11, 2006 | 10:51 PM
Honda_technician's Avatar
Default Re: Where is the transmission fluid??? (Chiovnidca)
if you are stillnot able to find it it is located to the right of the battery near the front of the trans you us the dip stick pipe to check and fill the transaxle fluid so you will need a funnel and if you need anymore help just PM me
Old Feb 11, 2006 | 10:56 PM
YeuEmMaiMai's Avatar
stand in front of the car (do this when it is cold)
on the left side look down at the bottom of the transmission as seen in this picture
item # 9 is dipstick and that is where you add fluid. I'd advice getting a really long funnel to make it a lot easier.
Canucksfan101
Feb 2, 2015 10:05 AM
britishdude
Dec 20, 2007 07:58 AM
St3v3
Feb 11, 2007 05:09 PM
..::91TEG-G2::..
Nov 15, 2004 05:35 PM
burbage
Apr 28, 2004 04:57 PM
