Does H22A4 Downpipe fit the H23 catalytic converter?
Old Feb 9, 2006 | 11:40 AM
NoVALude's Avatar
Default Does H22A4 Downpipe fit the H23 catalytic converter?
Getting ready to swap in an H22A4 and am having second thoughts about the exhaust system. Will the H22A4 downpipe connect to the H23 cat? Do they line up properly? Chassis is a 92 H23.
Thanks
Old Feb 9, 2006 | 12:52 PM
s13_240sx_92's Avatar
Default Re: Does H22A4 Downpipe fit the H23 catalytic converter? (NoVALude)
i believe it will if my memory serves me correctly (often it does not). The cat is shorter on the h23 though.
Old Feb 9, 2006 | 01:46 PM
AndyD's Avatar
The 5th Gen header (A4) is shorter in general. The Base header is the shortest, then is the Type SH, then is the 4th Gen H22/H23.
If you are asking if it will be the proper length, chances are....NO!
Old Feb 9, 2006 | 03:59 PM
InvaderTrax's Avatar
Just grab a regular 4th gen H22 header and it'll be fine. Or make an extension (I'd strongly advise against it seeing you can't buy the isosceles triangle flange anywhere
Old Feb 9, 2006 | 04:01 PM
snowblind7x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoVALude &raquo;</TD></TR><TR><TD CLASS="quote">Getting ready to swap in an H22A4 and am having second thoughts about the exhaust system. Will the H22A4 downpipe connect to the H23 cat? Do they line up properly? Chassis is a 92 H23.
Thanks
I just did that exact same thing on my car. It fits fine
Old Feb 9, 2006 | 05:42 PM
NoVALude's Avatar
Default Re: Does H22A4 Downpipe fit the H23 catalytic converter? (snowblind7x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">
I just did that exact same thing on my car. It fits fine </TD></TR></TABLE>
Cool thanks....it seemed that the SH exhaust was the one to watch out for.
prahjekt
Mar 2, 2008 09:45 AM
user 720822-1
Dec 31, 2006 07:36 PM
sLo h22
Mar 19, 2006 10:08 AM
shutta
Oct 9, 2005 10:34 AM
Midnightrayne
May 27, 2005 02:31 PM
