Help 2000 Si V2 Intake Install!
Old Feb 9, 2006 | 11:38 AM
E46Kid's Avatar
Default Help 2000 Si V2 Intake Install!
picture is big for easy to see what i am asking
1. i do not know what plugs or goes into it
2. crankcase breather the tube that connects to the intake from the valve cover!
my question is wtf do i do with hole #1?
Old Feb 9, 2006 | 11:57 AM
E46Kid's Avatar
bump! i know someone has to have a b series engine with a v2!
Old Feb 9, 2006 | 12:11 PM
sh!tsWEAK!'s Avatar
Default Re: (EkSi)
Do you have the crankcase breather tube connected to somewhere on the intake? If not, that's what you are supposed to do. I don't recommend just hooking it straight to the intake because you will be sucking all those crankcase vapors and other gunk into your intake manifold. Instead, run that line to a catch can, and then a line from the catch can to the intake.
If you already have the crankcase breather tube hooked into the intake and there is another hole on the intake that you don't know what to do with, just buy a little rubber cap thing from Advanced Auto Parts or Autozone or something and cap it off.
Hope that answers your question.
Old Feb 9, 2006 | 12:23 PM
iaredavid's Avatar
Default Re: Help 2000 Si V2 Intake Install! (EkSi)
for the crankcase breaher tube, there should be a nipple fitting on the intake pipe.
if i recall correctly, there should also be a place to plug in the intake air temp. sensor. (there should be a rubber grommet which meets the temp sensor.
Old Feb 9, 2006 | 12:27 PM
The Mista Mike's Avatar
Default Re: Help 2000 Si V2 Intake Install! (iaredavid)
Rubber gromet should go in the #1 hole for the intake air temp sensor. The crankcase breather will go to the little piece of pipe that protrudes from the intake.
Old Feb 9, 2006 | 01:49 PM
E46Kid's Avatar
ya there should be air temp sensor..but its just a hole that doesnt hook up into anything. I know what #2 goes into(crancase vapers)..just cant find anything with #1..for now i have a rubber stopper(put in myself) since its just an open hole.
anton_
Mar 12, 2007 10:56 AM
electronb16si
Jan 23, 2007 08:59 AM
shermanator
Mar 9, 2004 07:31 PM
D-Man
Dec 13, 2001 02:22 PM
