gauge cluster swap=no cluster light? searched...
Old Feb 9, 2006 | 11:02 AM
sol2hatch's Avatar
Default gauge cluster swap=no cluster light? searched...
Just swapped a UKDM gauge cluster into my 93 CX hatch, and now there is no back light. It was fine before the swap. I checked the dimmer switch and the fuse, and both are fine. When I did the swap, there was one extra plug that there was no place to plug in on the new cluster. Everything else on the cluster works fine. So whats that extra plug for, and why do I have no instrument light?
Old Feb 9, 2006 | 11:08 AM
3.point.2's Avatar
how man plugs does the UK one have? 3? im guessing that extra plug has something to do with the lighting
Old Feb 9, 2006 | 11:11 AM
sol2hatch's Avatar
Default Re: (h23eg)
I figured that might be the case, but I couldnt figure out why I hadnt heard about this problem on HT before. The UK one has the 2 big ones on the side, and the one yellow one in the middle toward the bottom.
Old Feb 9, 2006 | 11:35 AM
sol2hatch's Avatar
Default Re: (sol2hatch)
bump, i need this fixed before i go to work
Old Feb 9, 2006 | 12:12 PM
deathplaza's Avatar
do euro's come with airbags? was the extra plug yellow, if so its the srs plug.
Old Feb 9, 2006 | 12:22 PM
sol2hatch's Avatar
the extra plug is white, the yellow plug is already plugged in
does anyone know? I dont want to drive home in the dark with no instrument cluster
Old Feb 9, 2006 | 01:16 PM
Phillyhatch's Avatar
Default Re: gauge cluster swap=no cluster light? searched... (sol2hatch)
Is your car an automatic? If it is that plug is for the gear indicator lights and there is a red wire on that plug that goes to the dash dimmer. Try to jump a wire from the red wire to the red/blk (power wire from the fuse box) and see if that solves your problem.
Old Feb 9, 2006 | 01:30 PM
sol2hatch's Avatar
car is not an automatic, and neither is the cluster i got. I think that extra plug is for the shift light that comes on the CX model. Can someone verify this? And then tell me why my lights dont work!
Old Feb 9, 2006 | 08:02 PM
sol2hatch's Avatar
got it fixed. took cluster back out and plugged it back in, and it magically works now. Now I just have to figure out how to fix the dark spot on the left side of the tach!!!
Old Feb 9, 2006 | 08:43 PM
fms1day's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch &raquo;</TD></TR><TR><TD CLASS="quote">got it fixed. took cluster back out and plugged it back in, and it magically works now. Now I just have to figure out how to fix the dark spot on the left side of the tach!!!</TD></TR></TABLE>
I know this may be a noob answer but it could happen: have you check the cluster bulbs?
thevtecnician
Mar 25, 2009 04:56 AM
youre_scum
Jul 8, 2006 09:25 PM
invidiaeg6
Feb 11, 2004 11:49 AM
