ITR CAT Dimensions....
Old Feb 9, 2006 | 10:45 AM
unknown0001's Avatar
Default ITR CAT Dimensions....
Hey guys I've searched for this and couldn't find anything.
Does anybody know what the pipe inlet and outlet dimensions are for an USDM ITR catalytic converter???
thanks
Old Feb 10, 2006 | 04:44 AM
Default Re: ITR CAT Dimensions.... (Mr.RHTuner)
nobody knows?
Old Feb 10, 2006 | 06:24 AM
BSQ's Avatar
BSQ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Does anybody know what the pipe inlet and outlet dimensions are for an USDM ITR catalytic converter???</TD></TR></TABLE>
1.75" inside diameter
Old Feb 10, 2006 | 06:02 PM
JjuuN R's Avatar
Default Re: ITR CAT Dimensions.... (BSQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSQ &raquo;</TD></TR><TR><TD CLASS="quote">1.75" inside diameter</TD></TR></TABLE>
aka: too restrictive
Old Feb 11, 2006 | 08:03 AM
that's weird...I found an ITR cat for sale locally, the guy said the piping is 2" for inlet/outlet, and he stated it's a USDM ITR cat?
Old Feb 13, 2006 | 07:29 AM
BSQ's Avatar
BSQ
I would have the seller send you a picture of the inside measurement of the inlet and outlet.
Old Feb 13, 2006 | 09:05 AM
BudMan's Avatar
He's correct - I measured mine last night out since my header cracked I can't use the old stock one cause it's tooooooo small.
Old Feb 13, 2006 | 11:55 AM
gunnis's Avatar
Default Re: ITR CAT Dimensions.... (BudMan)
Just food for thought, I am curious as well.
How about JDM?
I was under the impression, Inner diameter was about 2.3X'' wide. While the outer diameter is right around 2''.
No?
Modified by gunnis at 3:05 PM 2/13/2006
Old Feb 13, 2006 | 02:15 PM
Anybody know of a good stock cat to run on a NA setup?
I would have thought that the ITR cat would be more ideal to use compared to a stock b-series cat
Old Feb 14, 2006 | 06:18 AM
BSQ's Avatar
BSQ
Default Re: ITR CAT Dimensions.... (gunnis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnis &raquo;</TD></TR><TR><TD CLASS="quote">
How about JDM?
No?
Modified by gunnis at 3:05 PM 2/13/2006</TD></TR></TABLE>
Yes, those are the correct measurements for the JDM ITR cat. I'm using one with my JDM ITR 4-1 header.
Old Feb 14, 2006 | 06:20 AM
BSQ's Avatar
BSQ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Anybody know of a good stock cat to run on a NA setup?
I would have thought that the ITR cat would be more ideal to use compared to a stock b-series cat</TD></TR></TABLE>
If you want to stick with stock/OEM, then the JDM ITR cat is your best choice.
RyCeRoCkeTz
10
Mar 10, 2007 03:42 PM
BoostR41
Nov 16, 2004 09:19 PM
stumpyf4
Jul 21, 2004 07:30 AM
SloEG
Nov 18, 2003 03:03 PM
ophdehEEzY
Oct 10, 2003 12:51 PM
