JDM ITR 2.5in Collector Header with usdm itr cat?
Re: JDM ITR 2.5in Collector Header with usdm itr cat? (pennies_hatchie)
is it because the inlet is too small? isn't the usdm itr cat a 2.5 inch inlet
Re: JDM ITR 2.5in Collector Header with usdm itr cat? (RyCeRoCkeTz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyCeRoCkeTz »</TD></TR><TR><TD CLASS="quote">is it because the inlet is too small? isn't the usdm itr cat a 2.5 inch inlet</TD></TR></TABLE>
no.
no.
what is needed in order for the cat to mate with the jdm itr header?
HT White Ops
Re: (RyCeRoCkeTz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyCeRoCkeTz »</TD></TR><TR><TD CLASS="quote">isn't the usdm itr cat a 2.5 inlet?</TD></TR></TABLE>
no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">no.</TD></TR></TABLE>
no.
Darth ModerVader
Some individuals claim to have successfully used a USDM cat with the JDM header. However, the inlet of the USDM cat is quite small (right around 2"), and the flare is not large enough to form a proper seal with the JDM flange. You will need an aftermarket cat with a 2.5" inlet, or a modified stock cat. Also keep in mind that the JDM header is a slightly different length than the USDM manifold, but this difference can be absorbed by the exhaust hangers.
Tommy_Gunns
04-13-2004 12:45 AM
