USDM 97 ITR ECU (P73)
like it says, i got a jdm ITR swap the guys told me it was a jdm ecu but it's not so i need to sell this ecu for another setup, but yea it's a P73, and i will let it go for 150 obo...
oh yea this ECU is the long style not like the small square that came in the 99-01, i believe
located in seattle
Modified by djstation at 10:24 PM 2/9/2006
Modified by djstation at 1:25 AM 2/13/2006
Modified by djstation at 1:53 AM 2/13/2006
Modified by djstation at 11:56 PM 2/23/2006
Modified by djstation at 12:00 PM 2/26/2006
located in seattle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstation »</TD></TR><TR><TD CLASS="quote">no pics right now but i am sure cause it says p73 A13 instead of p73 013</TD></TR></TABLE>
Just wondering, are you sure about the year?
https://honda-tech.com/zerothread?id=322483
I'm just making sure because I accidentally got a usdm itr 1998 ecu already and the difference is there is a gas pump pressure sensor on it that is not on the 97. I specifically wanted a 97 usdm itr ecu.
this ecu is obd2-A, otherwise 96-98 civic, 96-97 integra. will not fit unless your car is that year or if you have a jumper harness.
by the way, i had this ecu on my gsr motor, ran so ****** smooth. vtec crossover at 5,700 rpms, redline 8,500 rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol lovin »</TD></TR><TR><TD CLASS="quote">this ecu is obd2-A, otherwise 96-98 civic, 96-97 integra. will not fit unless your car is that year or if you have a jumper harness.
by the way, i had this ecu on my gsr motor, ran so ****** smooth. vtec crossover at 5,700 rpms, redline 8,500 rpms. </TD></TR></TABLE>
Yes, it's much fun
Yes, it's much fun
