Transmission questions???????
Old Feb 9, 2006 | 10:13 AM
wdelsolo's Avatar
Default Transmission questions???????
I have a B16a with a hydraulic tranny. The transmission housing is cracked. I am looking for an LS tranny cause I have heard they are good for turbo. Is that right? Will my exedy clutch and act flywheel form my b16a tranny work in an LS tranny. They are both hydraulic.
Old Feb 9, 2006 | 10:15 AM
wdelsolo's Avatar
Default Re: Transmission questions??????? (wdelsolo)
I am also needing to replace my axles. What kind would I be looking for if I had a B16a witha hydraulic LS tranny??????
Old Feb 9, 2006 | 10:28 AM
wdelsolo's Avatar
Can anybody help me out here? I havent yet bougt a tranny but need to very soon. Need advice. I will be running a peakboost turbo kit as soon as I get the tranny installed.
Old Feb 9, 2006 | 10:43 AM
wdelsolo's Avatar
Anybody know????????
Old Feb 9, 2006 | 10:50 AM
shiftgear8000's Avatar
ok....the LS tranny has longer gearing, so you will be in each gear longer then you would w/ the b16 tranny.....just depends what you like. As far as axles, clutch, and flywheel.....as long as it's b-series it will be alright.
Old Feb 9, 2006 | 10:51 AM
T
Everything is interchangeable between the trannies, clutch, flywheel, axles and what not. I have heard that the LS too is better for boost cuz of the longer gear ratios.
zccr-xsi
May 26, 2011 11:39 AM
cherryB-16a
Mar 29, 2007 06:57 PM
Type - ARman
Mar 10, 2005 02:20 PM
Ransom
Apr 3, 2003 06:32 PM
00SIBOOST
Jan 2, 2003 07:40 PM
