Civic stalls once warmed up...
Old Feb 9, 2006 | 04:59 AM
b17gsr's Avatar
Default Civic stalls once warmed up...
All right,
My father in laws 1993 Civic DX (stock everything) idles fine when cold, and drives fine. As soon as the temperature gauge starts to creep up and its idling (or loss of power while driving), it starts to miss and eventually stalls.
We’ve replaced the main relay, tried a new coil and ignitor. The problem persists.
Any other ideas?
Old Feb 9, 2006 | 05:11 AM
b_serious's Avatar
Default Re: Civic stalls once warmed up... (b17gsr)
ignition control module
Old Feb 9, 2006 | 05:16 AM
b17gsr's Avatar
Where's the ignition control module?
Old Feb 9, 2006 | 05:43 AM
b_serious's Avatar
Default Re: (b17gsr)
mine has the same problem, it only accures when the module is warm.. then it shuts off.. i'd try to find a used one cause mine was like 175 new.. its inside the distrubutor
Old Feb 9, 2006 | 05:49 AM
b17gsr's Avatar
But what is the ignition control module? The funny shaped black component in the distributor?!?!?!
b_serious's Avatar
yes, its almost an L shape
Old Feb 9, 2006 | 05:58 AM
b17gsr's Avatar
Cool, thanks.
Here's hoping it's the same component as the one in the 92-95 Integra distributor.
Old Feb 9, 2006 | 06:01 AM
AutoXer's Avatar
It may also be your IACV. Your cold idle valve may be holding the idle high, keeping the car running, but once it warms up, your IACV controls the idle.
Old Feb 9, 2006 | 06:30 AM
b17gsr's Avatar
I should have added that once it stalls, it won't restart until it has cooled down, it just cranks over and doesn't fire.
Old Feb 13, 2006 | 09:13 AM
b17gsr's Avatar
Replaced the 3 ignitor control modules, so far looks like the problem has been solved! WOOT WOOT!
canadianr
Oct 19, 2009 09:10 AM
skata89
May 21, 2006 06:23 AM
Ballinger
May 11, 2004 08:05 PM
