CUSTOM CRANK PULLEY.
does anyone here make custom crank pulleys?
I need one for a supercharged D series.
i can provide a pulley (for measurements or whatnot)
i'd prefer a little bit larger diameter than what i give you, with no accesories.
just a light weight, larger than stock crank pulley.
i know we got some machinists in here.
i have a really good machinist who i get custom parts for my store from. im not sure what itd cost, but i would guess around 200 or so. but i can definitely get it done. in 303 stainless...
-derek
-derek
Who is Mr Robot?
youd need some sort of dampening on the pulley... so you couldnt just turn a solid piece out of billet.... youd be guaranteing harmonics and as a result oil pump failure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">or you modify the stock pulley's diameter, and then turn off the smaller pullies you dont want, and balance...
streetwerks you should IM me, and we'll discuss my good idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">youd need some sort of dampening on the pulley... so you couldnt just turn a solid piece out of billet.... youd be guaranteing harmonics and as a result oil pump failure</TD></TR></TABLE>
i'm with you, i am not at all for the lighten or lightweight pullies. I've done the reasearch and am not happy with the findings. Race engines only is how I took it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">wouldnt it be easier to change the pulley on the supercharger? that one should be able to be billet without any problems.</TD></TR></TABLE>
yes, that is ONE way to upgrade boost.
but if you go too small, you risk belt slippage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">good point! i was just thinkin old school v8 blowers with the toothed pullies.</TD></TR></TABLE>
that be nice!
i am upgrading the blower snout pulley too.
that be nice!
How are you going to modify the stock pulley's diameter? when he wants it larger
</TD></TR></TABLE>How are you going to modify the stock pulley's diameter? when he wants it larger
These guys may be able to do a custom for you. http://www.unorthodoxracing.com/
Glenn
Glenn
boost, cost, crank, crankshaft, custom, damper, engine, fabrication, make, pulley, pulleys, randam, rrcycling, supercharger, tool
