can anyone help with mpfi swap.....
Old Feb 8, 2006 | 11:10 PM
ef9king's Avatar
Default can anyone help with mpfi swap.....
i have a 90 civic hb with a d16y7 no vtec but i cant get it right cause i dont get how to wireer the crank angle sensor i have it on paper by steps but it says use si distributor. but y when im not runing vtec no need for it right i need some help ...
Old Feb 8, 2006 | 11:33 PM
Deo's Avatar
Deo
Default Re: can anyone help with mpfi swap..... (ef9king)
None of the engines in the US ever had VTEC in our cars. You need an Si Distributor because the DX doesn't have a crank angle sensor in it (I could be wrong on that, I did a DX to ZC swap, but I know you need the Si distributor).
This thread has 3 differant complete guides on how to do the swap: https://honda-tech.com/zerothread?id=1508680
Old Feb 9, 2006 | 12:11 AM
davens's Avatar
They're talking about the distributor from an 88-91 D16a6 Si...no vtec.
Old Feb 9, 2006 | 12:32 AM
ef9king's Avatar
Default Re: can anyone help with mpfi swap..... (davens)
so get a si dis....how do i run the crank angle sensor.........
Old Feb 9, 2006 | 12:55 AM
Redline130's Avatar
The crank angle sensor is in the distributor, that's why you need the Si distributor since it has a crank angle sensor. The DX distributor does not.
Old Feb 9, 2006 | 01:34 AM
ef9king's Avatar
i have a obd 2 dis.. from that motor so can i repin it ond use that. im trying to get around buyin the si...
Dokta
Jul 31, 2007 02:36 PM
2fast4udude
May 9, 2006 08:57 AM
fox23
Jul 25, 2005 03:56 AM
hondafanatic1
Dec 23, 2003 07:28 AM
blacksoul
Oct 11, 2002 12:37 PM
