Distributor Hell!!!!!!
Im having lots of dizzy problems. So just finish swapping a ls motor into a ef hatch converted it to obd1. All is goin well starts right up. Then we get a code 8 which is tdc code. so check the resistance at all the wires all checks out both at the dizzy side and the ecu side. Swap distributors now we get a code 9 not a code 8. So is it possible we have 2 bad distributors i have checked the wiring over and over again. The resistance is good at both ends of the harness? Im stumped on this one and any help would be great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick »</TD></TR><TR><TD CLASS="quote">are you sure your timing is abosolutely correct and you didn't install your distributor 180 backwards?
You can't install late model honda/acura dizzy's backwards, they only go in one way.
More than likey its a wire that was overlooked or put in the wrong spot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">
More than likey its a wire that was overlooked or put in the wrong spot.</TD></TR></TABLE>
yea, im gonna check them all again tomorow I dont understand how having a wire wrong could cause a diffrent code with diffrent dizzy's? could the female end of the dizzys be diffrent?
well, i figured it out and come to find out the damn conversion harness was wrong. So if you are using a boomslang conversion harness be prepared for problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER »</TD></TR><TR><TD CLASS="quote">well, i figured it out and come to find out the damn conversion harness was wrong. So if you are using a boomslang conversion harness be prepared for problems</TD></TR></TABLE> ouch
PaChiLa Leader
Oct 10, 2005 09:38 AM
