will b18c swap work on 87 crxsi??
Old Feb 8, 2006 | 08:14 PM
Pnoyej6's Avatar
* B A N N E D *
Default will b18c swap work on 87 crxsi??
Im planning on buying 87crx si. Will the B18c1 swap into the crx??? Do they make motor mounts for it??
Old Feb 8, 2006 | 08:26 PM
StorminMatt's Avatar
Default Re: will b18c swap work on 87 crxsi?? (pnoytegn707)
Hasport makes a motor mount kit for B-series swaps into 1G CRXs. But there are still issues that must be dealt with. First of all, these mount kits are made for a cable transmission ONLY. There is no hydraulic conversion kit for this generation of Civics/CRXs. So if you use this kit (or likely any other that is available), you will have to separately source a cable transmission for the job. Secondly, there is the issue of the intake manifold. Now I have heard nothing in stone about this. But everyone suggests that the stock GSR intake manifold WON'T fit. With this said, you will likely have to go to a single runner style manifold such as the Skunk2 manifold. And finally, if you want to run the P72 ECU, a wiring conversion is in order.
Old Feb 8, 2006 | 08:30 PM
jlicrx's Avatar
Default Re: will b18c swap work on 87 crxsi?? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">Hasport makes a motor mount kit for B-series swaps into 1G CRXs. But there are still issues that must be dealt with. First of all, these mount kits are made for a cable transmission ONLY. There is no hydraulic conversion kit for this generation of Civics/CRXs. So if you use this kit (or likely any other that is available), you will have to separately source a cable transmission for the job. Secondly, there is the issue of the intake manifold. Now I have heard nothing in stone about this. But everyone suggests that the stock GSR intake manifold WON'T fit. With this said, you will likely have to go to a single runner style manifold such as the Skunk2 manifold. And finally, if you want to run the P72 ECU, a wiring conversion is in order.</TD></TR></TABLE>
and, you need to swap knuckles/hubs for ones from 86-89 Integra and get Hasport axles and shift linkage
Old Feb 8, 2006 | 10:52 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: will b18c swap work on 87 crxsi?? (jlicrx)
does these go the same for 88-91 crx si. Or should i look for a crx hf
Old Feb 9, 2006 | 08:19 AM
DEIVIONCRX's Avatar
a GSR will not go into a 84-87 CRX without a intake manifold swap, a B16/ITR or aftermarket manifold will be required
and yes you will need to swap to a Bseries Cable tranny, you will need hasport axles, 87 Integra knuckles alot of wiring, and hasport mounts, along with all the little **** that comes up
88-91 CRX with GSR wont be a problem just, mounts, shift linkage, axles and a lil bit of wiring
Old Feb 9, 2006 | 11:11 AM
SIXTY's Avatar
Default Re: will b18c swap work on 87 crxsi?? (DEIVIONCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">a GSR will not go into a 84-87 CRX without a intake manifold swap, a B16/ITR or aftermarket manifold will be required</TD></TR></TABLE>
Really?
Modified by sixty-seven point six at 12:22 PM 2/9/2006
Old Feb 13, 2006 | 02:46 PM
IKNOWHONDAS's Avatar
Default Re: will b18c swap work on 87 crxsi?? (sixty-seven point six)
nice
Old Mar 26, 2012 | 05:56 PM
mahoney206's Avatar
I have an 87' crx si that I would like to put either a b18 or b20 into it, the problem is I am new to it all including these forums. Also I would like to turbocharge whichever I end up putting into it. any ideas on what I need and what I should get?
sorry about posting it here but I just joined and cant make my own thread so I figured I would mooch off someone else trying to do a similar swap
THANKS!!
Old Mar 26, 2012 | 06:38 PM
KINGVEM^^ED6's Avatar
Check out redpepperracing.com guy
beef-cake
Feb 27, 2006 04:42 AM
crxkid24
Jul 28, 2005 07:13 PM
Coletrain
Apr 21, 2005 09:37 PM
donpeters
Feb 12, 2004 09:26 PM
