Intermediate Shaft??
hey guys I started out having a vibration throughout my whole car under acceleration... assuming that it was the axle I replaced my passenger axle of which was bad... with the vibration still existing I replaced my wheel bearing... still no luck... now i have replaced my transmission and still experience the same annoying vibration... is there anyway it could be the intermediate shaft? Has anyone ever heard of one going bad? Please help me out.. I've searched HT all over and it seems like no one has ever had this problem....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmteg93 »</TD></TR><TR><TD CLASS="quote">i had the same problem . napa gave me2 bad axles so i changed them under warranty and no more vibration . </TD></TR></TABLE>
hey man on those napa axles did they seem defective? the reason I'm asking is because that's what i have right now... were the joints stiff? anything weird about them?
Vibration under acceleration is due to a bad cv joint on one or both of the axles. I have been through three sets of shitty remanufactured axles that all had this problem. Do yourself a favor and stop buying remanufactured axles; they are complete junk.
I was fed up with it and ordered a set of Gator Stage 2 axles. I know that the joints are new and I will never have a problem with them again.
I have the same problem right now. evertime i coast, doing less than 20mph on neutral...its the worst. also when i turn slow it clicks pretty noticeably. it annoys the **** outta me...i have to turn up my radio to not hear the damn thing. i'll get that haft shaft taken care of this weekend though (hopefully).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo »</TD></TR><TR><TD CLASS="quote">Vibration under acceleration is due to a bad cv joint on one or both of the axles. I have been through three sets of shitty remanufactured axles that all had this problem. Do yourself a favor and stop buying remanufactured axles; they are complete junk.
I was fed up with it and ordered a set of Gator Stage 2 axles. I know that the joints are new and I will never have a problem with them again.</TD></TR></TABLE>
how much did they run you for the gator axles?
Bad motor mounts can cause that too, had same problem car's steering wheel would shake when i was on the gas around a corner, had two new alxels aready all suspension tight, put in some energy suspension motor mounts problem solved! just something to look at as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze »</TD></TR><TR><TD CLASS="quote">
how much did they run you for the gator axles?</TD></TR></TABLE>
$450 shipped for the Stage 2 axles. If you don't need something as strong, just a quality OEM replacement, they can make those too and at a much cheaper price.
I had a 91 DA that was notorious for going through axles quickly. I finally ended up getting some new ones through Raxles ( http://www.raxles.com/ ). They sell only new axles, no regrinds. Super customer service, I think the guys name is Marty maybe? They were $120 a side (no core charge provided you return your old ones in a timely manor....the even provide a free return shipping label). I highly recommend them. After using their axles, my problems went away.
hey guys i have found the problem after all this headache... it was the passenger side axle...
but now i have in a brand new axle from napa and it rides smooth as hell, i can't even remember my car being this smooth... haha.. i guess after all those months of the car vibrating i got used to it... good luck guys!
DTS
Oct 6, 2006 08:11 AM
