anyoen running a biger fuel pump in a crx??
Old Mar 25, 2002 | 11:29 PM
SUMORex's Avatar
Default anyoen running a biger fuel pump in a crx??
i need to get one ASAP and need to find out if the 99-00 civic si walbro 255l pump will work.
also is it true we have to drop the tank to get to it? i thought it would be as easy as my 00 si would be.
Old Mar 26, 2002 | 12:20 AM
jasonb's Avatar
Default Re: anyoen running a biger fuel pump in a crx?? (SUMORex)
Sumo, if you get rid of your OEM one on the CRX, let me know. I may want it for my CRX.
Old Mar 26, 2002 | 06:01 AM
Doodoo's Avatar
Go to http://www.autoperformanceengineering.com for a parts list.
You have to drop the tank to get to the pump. Its on the drivers side rear corner. PITA.
You may have to up the amps on fuse 14, most of us have blown it after installing the walbro pump.
Old Mar 26, 2002 | 06:13 AM
MIDNIGHT's Avatar
Default Re: anyoen running a biger fuel pump in a crx?? (Doodoo)
i used one from a awd eclipse. had to mod a bit but man the diffrence was worth it. and it only cost me 25 bucks
Old Mar 26, 2002 | 06:42 AM
Speed PHreak's Avatar
yeah it'll work, you'll just have to adapt the wiring harness on your crx pump assmbly to match the 99-00 Si pump. The CRX pumps use post-stlye connectors,m whereas the newer model use a plug. Easy enough to do though just get some spade connectors and extend your wires a bit and you're good. I recently swapped the pump in my HF out for a 94+ 'teg pump that I got for free. Works like a charm!
Old Mar 26, 2002 | 06:47 AM
TypeR0207's Avatar
Default Re: anyoen running a biger fuel pump in a crx?? (Speed PHreak)
I got a '99 Si pump, but am not going to install it until I do the swap.
Old Mar 26, 2002 | 02:47 PM
CRXRageD's Avatar
Default Hell yes I am.
I have a bosche thats somewhat ******* huge to say the least, check http://www.theoldone.com, that's the pump I'm running. The walbro pumps suck IMO. It loses pressure when at idle. Another pump I could reccomend that cycles like once every 5 mins is a AC delco R32 Skyline pump. Yes, it does fit. Tightly I might add. Still you will probably never need another fuel pump after you drop that badboy in. HTH,
Mr. Ito
dsettlemoir
Mar 25, 2008 11:32 AM
crazyjetsfan22
Oct 25, 2007 06:33 PM
spooned out
Aug 16, 2003 10:54 PM
spooned out
Aug 16, 2003 07:05 PM
spooned out
Aug 15, 2003 08:25 PM
