crx 255 inline pum?
Old Aug 15, 2003 | 06:38 PM
spooned out's Avatar
Default crx 255 inline pump help
need to knoe if a 255 walbro pump from a 95 civic si will work for a 88 crx si, but need to knoe what i have to do to get access to the crx fuel pump to switch if there compatiable? :
Modified by spooned out at 4:35 AM 8/16/2003
Old Aug 15, 2003 | 08:25 PM
crx1856's Avatar
to switch the pump you need to take off the two straps that hold the fuel tank on the underside of the car. then you need to unscrew the 6 10mm bolts on the top of the tank and pull out the pump. the pumps a little akward to pull out but it will come out.
dsettlemoir
Mar 25, 2008 11:32 AM
spooned out
Aug 16, 2003 10:54 PM
spooned out
Aug 16, 2003 10:02 PM
spooned out
Aug 16, 2003 07:05 PM
