Can You Use any TPS On Any TB?
Old Feb 8, 2006 | 05:46 PM
lvzero0's Avatar
Default Can You Use any TPS On Any TB?
Will a d16a6 TPS work on a d16y8 TB?
Old Feb 8, 2006 | 07:11 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Can You Use any TPS On Any TB? (lvzero0)
I believe any 88-95 civic tps is interchangeable.
Old Feb 8, 2006 | 07:57 PM
.john.'s Avatar
Default Re: Can You Use any TPS On Any TB? (mar778c)
just be carefull, the 88-91 dx tps and the obd2 dx tps rotate the opposite direction but the rest are the same
Old Feb 8, 2006 | 09:06 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">I believe any 88-95 civic tps is interchangeable.</TD></TR></TABLE>
Interchangable, yes, physically they will bolt on. But for some reason when I put a Z6 TPS on my A6 TB the idle shot up to 3k and it was set on the lowest possible idle voltage.
Old Feb 9, 2006 | 05:30 PM
tegsol1's Avatar
Old Feb 9, 2006 | 05:53 PM
lvzero0's Avatar
Default Re: Can You Use any TPS On Any TB? (tegsol1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr john &raquo;</TD></TR><TR><TD CLASS="quote">Interchangable, yes, physically they will bolt on. But for some reason when I put a Z6 TPS on my A6 TB the idle shot up to 3k and it was set on the lowest possible idle voltage.
well, I hope the a6 makes the y8 idle lower.
Old Feb 9, 2006 | 06:16 PM
hatchblack's Avatar
they may be obd specific. they do bolt up and plug in, but they may not run correctly. i put an obd 0 tps from my 89 si manifold into a 93 civic and it idled really well, and ran good, but there was no response after 3/4 throttle to full throttle. the car would actually stall out and wouldn't run. then i found a tps from another 93 civic and put it on and the car ran fine. the tps from my 89 worked just fine too in my civic just before i swapped motors a month prior to this.
SilverWarrior
21
Mar 14, 2008 07:09 PM
emooheo
Sep 3, 2007 05:47 PM
TomsSVX
Dec 14, 2006 08:27 PM
nek9
14
Nov 26, 2006 06:13 PM
deetz84
Sep 22, 2006 06:17 PM
