Clutch and Flywheel combo
Old Feb 8, 2006 | 05:39 PM
jdmB18CT-R's Avatar
Default Clutch and Flywheel combo
Im aware about the FAQ and read about final drive, but what would be the best clutch and flywheel for a JDM 97 ITR that's N/A street driven and sees the track on weekends?
my set up as for now
SI AEM intake and filter
98 JDM ITR headers
NGK iridium plugs and wires
Toda Spec A2 cams
Toda dual valve springs
Toda Ti retainers
Toda cam gears
and STOCK CLUTCH AND FLYWHEEL that's slipping as hell
Thanksss
Old Feb 8, 2006 | 05:40 PM
Dave_B's Avatar
I like my excedy setup. Matching FW and clutch.
Old Feb 8, 2006 | 06:11 PM
andyt's Avatar
Default Re: Clutch and Flywheel combo (jdmB18CT-R)
You seem to like Toda, so why not add a Toda flywheel and clutch...
Old Feb 8, 2006 | 06:16 PM
icefire069's Avatar
So far i'm loving my toda clutch and flywheel combo. Great hold and still very drivable. Stiffer than stock but your leg will learn quick.
Old Feb 8, 2006 | 06:44 PM
Aquafina's Avatar
Default Re: Clutch and Flywheel combo (icefire069)
Action 1MD clutch
Fidanza flywheel
nuff said.
Old Feb 8, 2006 | 07:02 PM
Tweakmeister's Avatar
Default Re: Clutch and Flywheel combo (Aquafina)
Flywheel - go as light as possible. THere is no debate, it's fine.
Old Feb 8, 2006 | 07:05 PM
Aquafina's Avatar
Default Re: Clutch and Flywheel combo (Tweakmeister)
7 pounds here....
4.71 FD....
2" clutch pedal travel....
6-puck unsprung.....
Invisible on the street.
Old Feb 8, 2006 | 09:31 PM
92TypeR's Avatar
FSAE
On my 1.8L I was running a Fidanza flywheel and Exedy OEM replacement disc w/~190whp, and no problems.
On my 2.0L I'm running the same flywheel with the Exedy 3-puck sprung disc. Its not hard to drive by any means, and it grabs well...
Keep in mind a puck clutch will have a shorter life, so if changing your clutch after 30k-40k isn't your idea of a good investment, consider something that is a full face disc. Although with the power you're making (mild) I would look into the Exedy organic disc, or some of the Action clutches.
Old Feb 8, 2006 | 09:35 PM
43MA's Avatar
Default Re: Clutch and Flywheel combo (92TypeR)
spoon and spoon for me
its very streetable
Old Feb 9, 2006 | 07:46 AM
shotenITR's Avatar
ACT streetlite 12.5 lbs and new OEM gsr clutch....works fine but I always wonder how much better a 6 puck would be.....
Old Feb 9, 2006 | 06:56 PM
ithrowpoop's Avatar
Default Re: (shotenITR)
matching exedy set-up. 9lb cromoly flywheel and organic clutch
Old Feb 10, 2006 | 04:02 AM
96BlackHB's Avatar
Toda Flywheel & ACT extreme plate/street disc, works quite well
Old Feb 10, 2006 | 11:20 AM
Vtecfool's Avatar
Default Re: Clutch and Flywheel combo (96BlackHB)
ACT HDSS clutch & ACT PROLITE (8lbs? i forget) Flywheel.
Old Feb 10, 2006 | 11:28 AM
RTW DC2R's Avatar
180-185ish whp, stock bbasso special clutch, CM 6.5lb FW
love it
qWiK hYbRiD
Nov 30, 2002 04:10 PM
R3dL1n3
Nov 17, 2002 01:31 AM
AamirCWITR
Oct 28, 2002 08:06 PM
BoostedGSRBubble
Sep 15, 2002 09:50 AM
nsx-Animal
Aug 13, 2002 05:21 PM
