Help with civic, fuel problem??
Old Mar 25, 2002 | 10:56 PM
1WHITELSS's Avatar
Default Help with civic, fuel problem??
My sister has a 90 or 91 civic 4 door DX. It's completely bone stock, has 5 spd tranny. Just recently, the motor starts to cut out going up hills, usually at highway speeds. Sometimes I can get it to start back up again right away in neutral, but lately had no luck at all!! I thought it had something to do with the distributor or fuel pump. She already had the main relay replaced, didn't work. And at the moment it's in the shop and the guy doesn't have a clue to what the hell is wrong. The motor has about 145,000 miles on it. IF ANYONE can help, please let me know, all suggestions are greatly appreciated. THANX
Old Mar 25, 2002 | 10:59 PM
1WHITELSS's Avatar
Default Re: Help with civic, fuel problem?? (1WHITELSS)
Anyone??? I don't know who to turn to. I know you guys have more experience and insight with this...
Old Mar 26, 2002 | 07:12 AM
REDBARON's Avatar
so it just cuts off when going up a hill? or does it do it at highway speeds? Is the ecu giving any codes?? Give some more info
Old Mar 26, 2002 | 09:03 AM
Urban Business
Guest
Posts: n/a
Default Re: Help with civic, fuel problem?? (VTECHatch)
sounds like a bad fuel pump
Old Mar 26, 2002 | 12:25 PM
OPTIMUS's Avatar
New User
Default Re: Help with civic, fuel problem?? (TorteX)
More than likely a fuel pump.
Check the fuel pressure.
Pressure should be like 32-38 psi.
Check spark plugs.
hope this helps
[Modified by 5 0 DIPPA, 9:26 PM 3/26/2002]
teknohatchie91
Apr 15, 2009 11:40 AM
zcmotor
30
Mar 17, 2008 05:53 PM
CRJenkins13
Dec 4, 2007 06:52 PM
rice a roni
Oct 23, 2007 09:34 AM
hwnstyle21
Sep 8, 2002 02:14 AM
