can a 6 puck clutch be used with just IHE and sum cams?
Old Feb 8, 2006 | 04:43 PM
VTECcnIT's Avatar
Default can a 6 puck clutch be used with just IHE and sum cams?
just like topic says. im thinkin this 6 puck is too crazy for my set up
Old Feb 8, 2006 | 04:55 PM
loudassVTEC's Avatar
Default Re: can a 6 puck clutch be used with just IHE and sum cams? (VTECcnIT)
A friend of mine was running a 4-puck, with an 8 lb flywheel on his stock LS hatch. Worked pretty good. Pretty hard to drive though. Held really good when he got boost!
Old Feb 8, 2006 | 05:13 PM
SlammedDC2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">A friend of mine was running a 4-puck, with an 8 lb flywheel on his stock LS hatch. Worked pretty good. Pretty hard to drive though. Held really good when he got boost! </TD></TR></TABLE>
Yep, If you have to drive up alot of hills or do stop and go traffic then that would be a dumb desission.
Old Feb 8, 2006 | 05:33 PM
sc4dr's Avatar
If you like the change in your ash tray flying out on take off go with the six puck, especially unsprung hub. Full face sprung hub ACT extreme street will hold up to about 400 hp, and maintain drivability
Old Feb 8, 2006 | 07:17 PM
LSvtec03's Avatar
Default Re: can a 6 puck clutch be used with just IHE and sum cams? (sc4dr)
i have an action 1md 6 puck, unsprung on my lsvtec in the crx with an 8 lb flywheel, and not much else. i love it. it's not hard to drive. the engagement is just a little different. if you are half a competent driver, you shouldnt have a hard time with it.
i had a friend with a 4puck, unsprung. that was a little crazy for me.
Ablack92hatch
Jul 20, 2008 02:02 PM
fracas
Mar 9, 2007 09:19 PM
MadSuRfEr
Jul 28, 2006 04:14 AM
Pee Wee
41
Sep 26, 2004 12:53 PM
TommyTom83
11
Aug 4, 2004 08:21 AM
