h22 tranz
Old Feb 8, 2006 | 03:59 PM
accordtype R's Avatar
Default h22 tranz
i have a honda accord with a f22 engine and i want to replace the stock tranz with a h22 tranz will that lign up and work
Old Feb 8, 2006 | 04:04 PM
jfish's Avatar
Default Re: h22 tranz (accordtype R)
What for
Old Feb 8, 2006 | 04:05 PM
hondaracin24's Avatar
yes all f series and h series motors and trannies are interchangeable
Old Feb 8, 2006 | 05:06 PM
iam7head's Avatar
Default Re: h22 tranz (hondaracin24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracin24 &raquo;</TD></TR><TR><TD CLASS="quote">yes all f series and h series motors and trannies are interchangeable</TD></TR></TABLE>
yes but do your search on
gas mileage loss
short gear ratio on f series engine
Old Feb 8, 2006 | 05:15 PM
YeuEmMaiMai's Avatar
is your current trans bad? If you change it out you will definately get much improved accelleration times. Unfortunately you may end up commiting suicide after you go insane from hearing your engine at 4K when you are driving 70.
Old Feb 9, 2006 | 09:31 AM
b_ron007's Avatar
Default Re: h22 tranz (YeuEmMaiMai)
actually, that would be 4,000rpms @80mph. and yes......the acceleration is a night and day difference, i don't think you would regret it, but it does depend on how much you desire it.....there is the draw back......and that would be the gas mileage, BUT.....on my F23 engine i'm getting 300 to a full tank before the gas light comes on.....BUT i'm also getting 8 miles for every 7 miles, so do the math..... i also have to mention i'm always getting on it AND those miles are all city driving, SO to me it was well worth it and not any other mod would have improved acceleration more then the tranny swap other then turbocharging the engine or nitrous. H22 ludes don't even pull away from me......above and beyond 100mph would be a different story tho, top speed is lowered due to the shorter gearing and as you know or should know, the F-series engines don't make high reving horsepower but it makes up in low-end torque which definitely helps out acceleration.
a H22 tranny swapped F engine.......mod for mod will beat the a F22 or F23 tranny down the 1/4 but topspeed topping out over 140 mph on highway runs the H22 tranny will never see the light of day UNLESS the engine is highly modified for high reving.....SOO yes theres is some draw backs
if ur tranny is crapped out i highly reccomend the H22 tranny, yes there is also the H23, but longer gearing then the H22 means slower and if you trying to maximize acceleration then H22 is the way to go.
just my 2cents and this comes from my experience with the H22 tranny.
Old Feb 13, 2006 | 01:50 PM
JDM4DRACCORD's Avatar
the h22 tranny is great on the F. shorter gears its wonderful. And your gas will only go down based on how you drive. Haul *** no gas, drive easy good gas mileage.
Its your car do what makes you happy.
jeremy.
244
Sep 15, 2007 10:07 AM
effinnwackk
Jan 7, 2005 10:06 PM
lildrgn2.0
Jan 5, 2004 10:56 PM
chidoks
Oct 18, 2003 06:34 AM
AllMotorDC2
Jun 7, 2003 11:08 AM
