RPM wont pass 2500
Old Feb 8, 2006 | 03:25 PM
KloC 95 EG's Avatar
Default RPM wont pass 2500
Everytime im in 4th and 5th gear n step on the gas pedal it wont pass 2500 on the rpm the speed will slowly accelerate higher but the rpm doesnt pass 2500 any ideas whats wrong? and how to fix it? and i have a stock single cx motor
Old Feb 8, 2006 | 05:03 PM
old man neri's Avatar
Default Re: RPM wont pass 2500 (KloC 95 EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KloC 95 EG &raquo;</TD></TR><TR><TD CLASS="quote">Everytime im in 4th and 5th gear n step on the gas pedal it wont pass 2500 on the rpm the speed will slowly accelerate higher but the rpm doesnt pass 2500 any ideas whats wrong? and how to fix it? and i have a stock single cx motor</TD></TR></TABLE>
is this an auto or manual?
Old Feb 8, 2006 | 05:58 PM
KloC 95 EG's Avatar
Default Re: RPM wont pass 2500 (old man neri)
manual
Old Feb 8, 2006 | 08:40 PM
KloC 95 EG's Avatar
bump
Old Feb 8, 2006 | 08:52 PM
Boostage's Avatar
Are u throwing codes?
Old Feb 8, 2006 | 08:56 PM
74celicagt's Avatar
is it your clutch slipping?
Old Feb 8, 2006 | 09:36 PM
Default Re: (74celicagt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 74celicagt &raquo;</TD></TR><TR><TD CLASS="quote">is it your clutch slipping?
I doubt it, if his clutch was slipping his RMPs would go high and his speed would stay the same.
I am thinking just a stuck tach or something. If the car continues to accellerate then it can't really be the tranny, can it?
Old Feb 9, 2006 | 12:32 AM
74celicagt's Avatar
right.
I got myself confused cause I was thinking back to an article I read about the tranny they put in the VX I think. the 1 speed belt type or something. the article said that it felt weird cause it seemed like it was a slipping clutch under acceleration or something. I'll also blame it on me being tired. lol
Old Feb 9, 2006 | 02:35 AM
Syndacate's Avatar
wait, when you're in 4th, and you floor it, and it gets to 2500 RPMs, is ur speedo still going up (are you going faster) and your tach staying where it is, or is the engine not going past 2500 RPMs in 4th (the car's not accelerating at all, speedo's at the exact same speed as it was 10 minutes ago with it floored)
Old Feb 9, 2006 | 09:47 AM
kkitzman's Avatar
i had the same problem with my 93 cx the problem was the dumbass who did the valve job on it forgot to put the seals in it, so it clogged the cat and it got fucked up so i doubt that ur cat is clogged but thats just what happened to me
Old Feb 9, 2006 | 09:57 AM
IHateJDM's Avatar
Default Re: RPM wont pass 2500 (kkitzman)
I don't see how the rpm's could stay steady and the car still accelerate in a manual, unless its just a bad sensor/tach.
Old Feb 9, 2006 | 10:21 AM
Archidictus's Avatar
Unceasing Measure
Default Re: RPM wont pass 2500 (IHateJDM)
Let's see. The CX has monster gearing, so in 5th gear at 2500mph you're going...well over 100mph right?
The thing has like 12hp. What the expletive do you expect? It will slowly go faster, but the RPM won't go up to your eyes because at that speed it would take 1400hp to get it to redline.
Old Feb 9, 2006 | 04:52 PM
ExCon's Avatar
Default Re: RPM wont pass 2500 (Archidictus)
similar thing happend to me, so i cheked the code it was throwind and it ended up beign that my car was running lean, so i went to autozone and i picked up so fuel system cleaner for like 15 bucks and one hour later i was vroom vroooming down the ghetto streets of tustin!!!!
Old Feb 9, 2006 | 06:08 PM
92civichatch1's Avatar
Default Re: RPM wont pass 2500 (JDMedEK)
i had the same problem but in every gear. it turned out to be the dizzy. i forget which part malfunctioned. After i put the new one in she ran fine.
Old Feb 10, 2006 | 02:09 PM
ExCon's Avatar
Default Re: RPM wont pass 2500 (92civichatch1)
check the codes on the engine.
Old Feb 10, 2006 | 03:11 PM
crxsi8's Avatar
Id check grounds..same problem with my buddies GSR hatch..its was a loose ground..
Scotty2H
Sep 10, 2007 02:44 PM
SOLO1racer
Jan 25, 2005 07:37 PM
projectej8
26
Jul 3, 2004 09:31 AM
HUBB
24
Sep 30, 2003 12:34 PM
