Headlight out after header install????
I just installed a header on my car and had to pull the driver side fan to get the header out. The install went fine but now when I started up my car and went for a ride my driver side headlight is out. The high beam works fine it's just the low. Any ideas as to what happened????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">Did the header melt a wire? Didd you pull a bit too hard on a wire? Maybe you jsut have shitty luck?</TD></TR></TABLE>
I figure it's just a wire that got pulled out, any idea if the wires connected to the fans have any connection to the headlights??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 1102 »</TD></TR><TR><TD CLASS="quote">did u even check the bulb ? maybee it was just time for it to go.</TD></TR></TABLE>
That's my next step, it's just too coincidental that I start yanking wires and the headlight decides to burn out at that very moment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 »</TD></TR><TR><TD CLASS="quote">
That's my next step, it's just too coincidental that I start yanking wires ....</TD></TR></TABLE>
Yanking =
Yanking =
That's my next step, it's just too coincidental that I start yanking wires and the headlight decides to burn out at that very moment</TD></TR></TABLE>
probably has something to do with why it's not working in the first place
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 »</TD></TR><TR><TD CLASS="quote">I just installed a header on my car and had to pull the driver side fan to get the header out. The install went fine but now when I started up my car and went for a ride my driver side headlight is out. The high beam works fine it's just the low. Any ideas as to what happened????</TD></TR></TABLE>
I say check the fuse, and go from there to replacing the bulbs
variable
Aug 6, 2005 12:37 PM
