zc in 91 sadan?
Old Feb 8, 2006 | 09:45 AM
doberneckerj's Avatar
Default zc in 91 sadan?
on the wiring ive already swaped the injector wiring and im stumped on the distributer wiring. i have both harnesses but the factory ecu. i have 3 wires on the distributer and i dnt no how 2 hook it up 2 my ecu, or stock harness? it was my daily driver so i need help quick. thanx!!!
Old Feb 9, 2006 | 06:38 PM
Default Re: zc in 91 sadan? (doberneckerj)
anybody no how?
Old Feb 9, 2006 | 06:45 PM
mikerbike's Avatar
You won't be able to run MPFI on your stock ECU. Get a PM6, PM7, PG7 or a PR4 and if you absolutely run out of options, a PM8.
Old Feb 9, 2006 | 06:52 PM
Default Re: zc in 91 sadan? (mikerbike)
i was told to swap around some pins in the ecu and add a couple. that should work. i have a diagram how 2 but its a lil off on the distributer part.
Old Feb 9, 2006 | 07:00 PM
ek_slut's Avatar
yea you have to switch wires at the ecu....but the ecu in there is for DPFI (pm5 i believe)....you need one for MPFI (pm6, pg7, etc)
Old Feb 11, 2006 | 08:24 AM
mikerbike's Avatar
Yeah, what he said^^ About that distributor... You will need a MPFI distributor too. The DPFI distributor doesn't have the NO. 1 Cyl. Position sensor in it. The MPFI distributor does. You can run the MPFI without that sensor, it just won't ever run as well as it could. You will have a loss in power and bad gas mileage.
Old Feb 11, 2006 | 09:14 AM
i have the mpfi distributer but the diagram telling me how 2 wire it up is a lil off. and it has a cam position senser and it is supposed 2 be wired in the same step as the distributer. the dpfi has an internal coil and the mpfi distributer that i have has a coil seperate. that all makes 4 a pritty good nitemare.
Old Feb 13, 2006 | 05:19 PM
mikerbike's Avatar
Then you don't have a factory MPFI distributor. The coil was located inside the distributor on all 88-91 Civic and CRX engines. If you want MPFI, you will need an MPFI ECU. That's all there is to it. It sounds like you need to find a different source for your info.
dellman177
May 12, 2005 07:39 PM
ITR981002
Apr 1, 2004 02:34 AM
HybriDNA
Feb 13, 2003 03:56 AM
serious
Jan 6, 2003 06:12 AM
