Doing a minime swap Z6 head and D15b2 block should I change the head studs???
Old Feb 8, 2006 | 09:16 AM
Screaming's Avatar
Default Doing a minime swap Z6 head and D15b2 block should I change the head studs???
D16Z6 head going on a D15b2 block getting the original head studs with the head which had 106,000 miles on it.My question is: I know it probably won't hurt to use new studs but I'm looking to save a liitle money here and there and would it be a good idea to skimp on this??? Can I even use the Z6 head studs on my d15b2 are they interchangeable???? Thanks
Old Feb 8, 2006 | 12:28 PM
Screaming's Avatar
Default Re: Doing a minime swap Z6 head and D15b2 block should I change the head studs??? (Screaming)
Come on we gotta have some opinions on this can I get away with using the OEM studs even with the increase in compression????
James_Starks
Oct 8, 2010 08:58 PM
EF9ZC
Mar 21, 2006 11:49 AM
JDMKid71
Feb 13, 2006 07:05 PM
spun Vtec
Dec 6, 2005 01:11 PM
Jizzmaster Zero
Sep 6, 2005 10:47 AM
