how much nos+stock ls block=boom
Old Feb 8, 2006 | 08:58 AM
cm zak's Avatar
Default how much nos+stock ls block=boom
im thinking a 50 dry shot would be ok for street driving lemme know
Old Feb 8, 2006 | 09:07 AM
BrooX's Avatar
Default Re: how much nos+stock ls block=boom (cm zak)
Search Results
Your search for Nos returned 46 results.
Our search function is great....
Old Feb 8, 2006 | 09:15 AM
DA jeshy's Avatar
yea thats what i am looking into when i am saving up for my ls vtec.
if you are going to run 50 i would retard you timing. especially on stock block nos burns faster so if you retard it the it will be detonating at the right time. you dont have to but you dont want to waist that **** it cost green to fill it up
Old Feb 8, 2006 | 09:18 AM
shiux's Avatar
i agree that people should use the search function, but if everyone did that, this forum would be dead with nearly NO activity. i dont see the harm in asking if someones willing to answer
Old Feb 8, 2006 | 09:53 AM
Vi3tboy's Avatar
you should be fine. im irunning 55 shots off of the zex kit. make sure you use 93 octane and get colder plugs.
and dont forget to have fun
Old Feb 8, 2006 | 01:05 PM
crix868's Avatar
im not sure but my cuzin sprayed 100 wet shot for like 3yrs on stock internals tuned
Old Feb 8, 2006 | 02:40 PM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">im thinking a 50 dry shot would be ok for street driving lemme know</TD></TR></TABLE>
50 will be fine. 75 will be fine. 100 will probably be fine (as long as you use a dry kit or direct port)
50 shot on a ls you don't need to retard the timing, just run 91 or 93. colder plugs, bottle heater will help, purge is always good. window switch is good to have.
Modified by H23 Power at 7:20 PM 2/8/2006
Old Feb 8, 2006 | 03:53 PM
IntegrasAreBest's Avatar
Default Re: how much nos+stock ls block=boom (H23 Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power &raquo;</TD></TR><TR><TD CLASS="quote">
50 will be fine. 75 will be fine. 100 will probably be fine (as long as you use a dry kit of direct port)
50 shot on a ls you don't need to retard the timing, just run 91 or 93. colder plugs, bottle heater will help, purge is always good. window switch is good to have. </TD></TR></TABLE>
my thoughts exactly
Old Feb 8, 2006 | 04:02 PM
loudassVTEC's Avatar
I ran a 75 NX wet kit, on the b16 for awhile with not the first problem. Just make sure your air/fuel mixture is right, and you'll be fine. You don't have to worry about timing until you get to a 100 shot. Then you might want to retard the timing a couple degrees.
EDIT: It's not called NOS. NOS is a brand name. Calling nitrous NOS, is like calling every car a Ford. Not trying to be a dick, just letting you know for future reference. It's a common mis-conception created by the Movie "The Fast and the Furious".
Old Feb 8, 2006 | 07:32 PM
lokodog's Avatar
I don't know about using 100 shot on a dry system with stock injectors. I don't personally know on these motors because i still don't know too much about them, but it sounds like a lot to run on stock injectors.
My friends stock d16 was pumping 125 shot through a wet system and ran fine until someone hit his car. But then again; thats a wet system, so the fuel was already being supplied elsewhere and didn't push the injectors any harder.
Anyone else know a little more about this that cares to comment?
stlh22civic
Mar 24, 2006 11:41 PM
vmsturbo
Aug 21, 2004 06:29 PM
aaaallll04
Oct 21, 2003 06:58 PM
wm5holla
Jan 19, 2003 11:59 PM
RacerXintegra2k
Nov 16, 2002 05:22 PM
