dpfi into mpfi
Old Feb 8, 2006 | 08:15 AM
na91hatch's Avatar
Default dpfi into mpfi
my friend has a spare intake manifold w/ fuel rail and wiring off of his 94 cx (d15). I was wondering if anyone knows if i can directly bolt on the intake manifold. I know i will need a new ecu, but what kind of wiring adjustments would i have to make and want kind of ecu would i need? thanks
Old Feb 8, 2006 | 08:31 AM
ZChatch90's Avatar
Default Re: dpfi into mpfi (na91hatch)
since u are going to be obdo harness u will need the si harness from a 88-91 hatch or u can go to RYwire.com and they will make u sen in ur dpfi and modifie it to be mpfi. but u will need a resistor box for the injectors and some injector plugs. i have done a wire harness conversion to my friends dpfi and made it mpfi for a ZC but i had the help of the core pin numbers and ecu pin number charts along with step by step instructions on which pins to move and place new pins i do not have the conversion papers anymore i sold them for 50 bucks so sorry but u can get urs done by rywire.com and it is pretty cheap.
ps. if u are going to use that intake set up on ur motor u will need to have a PM6 which is the si ecu.
Old Feb 8, 2006 | 09:36 AM
Rywire's Avatar
Default Re: dpfi into mpfi (ZChatch90)
Yup, a dpfi to mpfi is needed... and the si harness is good for parts, but it wont bolt up
Ryan
Old Feb 8, 2006 | 01:38 PM
doberneckerj's Avatar
all u have 2 do instead of buying the wiring is swap around some pins in ur ecu and adding 2. a mpfi needs a cylinder senser and 2 do that u have 2 swap pins from C1 to B10 and C2 to B12. and 2 additional wires from A3 for injector #4 and from A7 to injector #2. ur factory injectors are going to be injectors 1 and 3. then u run the other 4 wires from the injectors to a resister box that u can get out of anything. i got mine out of a 87 integra but i did the zc swap also.
Old Feb 8, 2006 | 03:40 PM
bluk20's Avatar
I wauld go the way doberneckerj said its the cheepest way and it works why wast money. To get a step by step process go to http://www.hybrid honda.com they explain it in detail there. there is no reason it wouldnt work
Old Feb 8, 2006 | 04:20 PM
court's Avatar
25 Year Member
Default Re: dpfi into mpfi (rustyb16ef)
if you feel like saving your self some time, purchase a dpfi to mpfi wire harness and a jumper harnes(if you are going to be using an obd1/2 ecu)
the wire harness is money well spent, the time it takes, its worth it. but if you are in it for the educational value, you cant sacrafice that
Old Feb 8, 2006 | 04:23 PM
Rywire's Avatar
Default Re: dpfi into mpfi (court)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">if you feel like saving your self some time, purchase a dpfi to mpfi wire harness and a jumper harnes(if you are going to be using an obd1/2 ecu)
the wire harness is money well spent, the time it takes, its worth it. but if you are in it for the educational value, you cant sacrafice that</TD></TR></TABLE>
Old Feb 9, 2006 | 06:31 PM
tegsol1's Avatar
http://gutterslide.com/fourthg....html
cgross
Dec 23, 2012 12:08 AM
92 teggy
Jan 11, 2010 12:22 PM
1997 gsr
Feb 9, 2009 10:09 AM
16v
Apr 18, 2008 07:19 AM
luigi69
May 7, 2006 03:25 AM
