H22 EG question about 5wire to 4wire 02
Old Feb 8, 2006 | 08:04 AM
jmayhew's Avatar
Default H22 EG question about 5wire to 4wire 02
I did some searching but didn't really find what i needed.
i have a H22a4 swapped into a 92 VX.
using a p13 ECU (ODB1)
i'm pretty sure my 02 is going bad...occasionally I get a 1 & 43 CEL.
i have a 5 wire O2 lying in my garage from the VX motor we took out.
is there a way to use this to replace the 4wire O2 the h22 is using?
also heard you can wire it to run a wideband? is this true?
let me know what my options are.
would prefer to use what i have then to have to buy a new O2
Old Feb 14, 2006 | 10:41 AM
jmayhew's Avatar
Default Re: H22 EG question about 5wire to 4wire 02 (jmayhew)
anybody????
Old Feb 14, 2006 | 06:31 PM
schardbody's Avatar
i will take that O2 off your hands if you dont need it PMed you.
Old Feb 28, 2006 | 10:03 AM
jmayhew's Avatar
Default Re: (schardbody)
still need some info on this???
Old Feb 28, 2006 | 02:08 PM
Relic1's Avatar
your ECU needs a four wire O2, the five wire is totally different and not compatable.
Sell it and buy a four wire.
the VX uses a L1H1 wideband 5-wire O2 sensor. You can create a DIY wideband controller to run it. google DIYWB
Old Feb 28, 2006 | 09:40 PM
Turbo_Mike's Avatar
Default Re: (Relic1)
I think your gonna need to swap a wire from the unused vx plug on the passenger side shock tower to an empty slot on the big plug between a brown and a black wire.... Check it out, i'm not 100% if its the same for a h22, but i think thats what u need to do to run a 4 wire o2
vxtirent08
Apr 15, 2008 10:15 AM
BlownEJ6
Sep 18, 2003 06:42 PM
FMIDRC Racer
Aug 17, 2003 08:39 AM
H23vtecEG
Apr 4, 2003 08:12 AM
civic_dreams95
Mar 11, 2003 11:08 PM
