Rear Disc Break Conversion on EF9
Old Feb 7, 2006 | 07:30 PM
QuickRexSi21's Avatar
Default Rear Disc Break Conversion on EF9
Im putting a CRX rear disc break conversion on my friends hatch, does anyone know of an easy way to put the Break lines in?? it looks like i gotta take out heat shield any info will help out, thanks
Old Feb 7, 2006 | 07:36 PM
zxc4's Avatar
use jack stands, your gona be under the car for a while
Old Feb 7, 2006 | 08:02 PM
Targa250R's Avatar
be professional
Default Re: Rear Disc Break Conversion on EF9 (QuickRexSi21)
EF9 comes with rear disc brakes from the factory.
Old Feb 7, 2006 | 08:20 PM
Mach69's Avatar
Default Re: Rear Disc Break Conversion on EF9 (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">EF9 comes with rear disc brakes from the factory.</TD></TR></TABLE>
Yes it does, but in his profily he clearly says he has a crx si with a b16 engine, which leads me to assume its USDM and not JDM, which would not make it the ef9. Yea, use the crx trailing arms, also use 92-93 integra GS-r e-brake lines and yes, take off the heat shield from the exuast and you will be under there for a while.
Old Feb 7, 2006 | 08:39 PM
Riceburner247's Avatar
Default Re: Rear Disc Break Conversion on EF9 (Mach69)
I installed my braykes in a couple hours. They were the breaks off a DA, but I didn't get the E-brache cables, so it was a quick install.
Old Feb 7, 2006 | 08:42 PM
Rywire's Avatar
Default Re: Rear Disc Break Conversion on EF9 (Riceburner247)
anyone ever "make" the drum brake cables work?
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">I installed my braykes in a couple hours. They were the breaks off a DA, but I didn't get the E-brache cables, so it was a quick install.</TD></TR></TABLE>
LOL, I get the humor in this now!
Old Feb 8, 2006 | 01:02 PM
zxc4's Avatar
gimme a brake
Old Feb 9, 2006 | 06:06 AM
green91's Avatar
can you use the drum brake lines with the rear disc conversion? (the hydraulic lines themselves, not the parking brake cable)
EDIT: I searched, and you must use the integra or CRX 90-91 si lines, they are different than the drum brake lines.
Old Feb 9, 2006 | 07:56 PM
okay thank you guys, i appreciate the help this saturday ill let you know how it goes,
A usdm Civic Si has Drum breaks BTW, i am using the crx rear disc break set up, i got the Integra lines. i just came to find out my friend lost all the bolts to put the calipers together along with the brackets....great..junk yard trip for us!!!! how about the hydraulic Line?? can i use any attatchment to put on the caliper? i dont know if im being clear about what i am asking...
Old Feb 9, 2006 | 07:59 PM
Default Re: Rear Disc Break Conversion on EF9 (droppedcrxsi)
i get it now HAHA
Old Feb 9, 2006 | 08:01 PM
Default Re: (green91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">can you use the drum brake lines with the rear disc conversion? (the hydraulic lines themselves, not the parking brake cable)
EDIT: I searched, and you must use the integra or CRX 90-91 si lines, they are different than the drum brake lines.</TD></TR></TABLE>
nevermind, i should have read everything....what a dumbass i am. thanks man
Old Feb 10, 2006 | 03:31 PM
green91's Avatar
i put on DA rear discs on my hatch today. the e-brake lines are by far the hardest part of it all. the da e-brake lines fit perfect! the holding brackets even line up perfectly. i do think it makes my wheels sit outward a little more.
Old Feb 10, 2006 | 03:40 PM
tomorrow i will be doing my friends break lines, i need to go find some DA or Si Hydraulic Lines to attatch, and the bolts that are "missing" HA! thanks for the heads up!
Old Feb 23, 2006 | 03:20 PM
green91's Avatar
I did a before and after alignment with my rear disc.. even if you leave your compensator arms alone, DA rear disc do knock your rear toe out of alignment. on mine it was nearly .2degrees on each side.
Old Feb 23, 2006 | 04:03 PM
trrbl1bmx's Avatar
I seriously don't understand why it is so hard for people to spell brake!!!! WTFFFF!
Old Feb 23, 2006 | 06:27 PM
FernEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">I did a before and after alignment with my rear disc.. even if you leave your compensator arms alone, DA rear disc do knock your rear toe out of alignment. on mine it was nearly .2degrees on each side.</TD></TR></TABLE>
yea just did my drum to disc about a week ago and i had the same problem.. but then after awhile from driven the rear balanced itself out.. but i also used the Da lower control arm so i dont know if that really makes a dif cause they bolt right up
Old Feb 23, 2006 | 08:28 PM
Jstuneshop's Avatar
guys, do you not know that the da spindles bolt right up to a civic ef rear trailing arm, thats what i just did and it works perfect, dont waste your time puting the da trailing arm on. it is so simple and i can not believe that any body had not reviewed this on HT !!!!!!!
Old Feb 23, 2006 | 08:54 PM
Default Re: (Jstuneshop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jstuneshop &raquo;</TD></TR><TR><TD CLASS="quote">guys, do you not know that the da spindles bolt right up to a civic ef rear trailing arm, thats what i just did and it works perfect, dont waste your time puting the da trailing arm on. it is so simple and i can not believe that any body had not reviewed this on HT !!!!!!!</TD></TR></TABLE>
i used the crx BRAKES..(HAPPY NOW??) yeah, so they just bolted right up....im still waiting for the rain to stop so i can go to the junk yard and pick up a few caliper bolts and the hydrualic hoses to connect the caliper....ill take picz and post them to show you how they look. the arms are exactly the same. drum and disc. i just got some from a CRX Si 1991, it fits perfect...i dont see how the camber is going to be affected.
Old Feb 24, 2006 | 02:29 PM
green91's Avatar
the camber isnt affected.
i finally put my front DA brakes on day.. ive got 3 alignment sheets now.. pre-any work, da rear disc, and full da-brakes. ive found that 99% of the information regarding da brakes and their affects on alignment are WRONG.
First off, rear DA disc will affect your rear toe regardless of whether or not you mess with the compensator arms. the camber and caster are not affected. the DA rear disc DO move your wheel outward approx 1/4" and can cause rubbing problems.
Front DA brakes also knock the toe WAY off. i had 1.5degs toe in on each wheel for a total of 3 degrees cross toe when i converted! Caster is NOT affected. However, the DA front brakes caused my camber to become even more negative than it was previously, contrary to what everyone on here says. ive notice nearly no change in steering effort or feel.
hope this helps to clear some of this information up. i will try and come up with a way to post the three alignments i did to show the affects of the DA brakes.
1996Civic_CX
Sep 7, 2008 11:55 AM
iheartmyh0nda
Apr 21, 2007 12:46 PM
eg:R
Jan 29, 2006 06:50 PM
88turdbucket
66
Sep 14, 2005 12:47 PM
acurateggy93
Apr 12, 2005 10:12 AM
