noone likes wheel hop ...
Old Feb 7, 2006 | 05:16 PM
3s0n3's Avatar
Default noone likes wheel hop ...
whats your favorite traction setup to eliminate hop in a crx?
Old Feb 7, 2006 | 05:23 PM
Ak_ef9's Avatar
Default Re: noone likes wheel hop ... (ESONE S1)
do a search before you post stuff.
here I did the work for you
https://honda-tech.com/zerothread?id=1156671
Old Feb 7, 2006 | 05:25 PM
VtecSyndrome's Avatar
Tokico 5-ways with Skunk 2 coilovers!!!!!!, best bang for the buck. Traction bars help also but depending on your power output you may not need one. If your running all motor you can usually get away with out using the traction bars. I eliminated wheel hop completly in my '88 CRX Si with the D16a6 and I/H/E, it was not as quick as my B16 powered CRX and since I have not gotten 5-ways up front yet (only have blues on Skunks right now) I am not sure if that will be all I need. I will know in a few weeks though.
Old Feb 7, 2006 | 05:27 PM
Pee Wee's Avatar
Default Re: noone likes wheel hop ... (VtecSyndrome)
full-race traction bars
Old Feb 7, 2006 | 06:31 PM
si0385.'s Avatar
Default Re: noone likes wheel hop ... (Pee Wee)
if its lowered i would start with a camber kit instead of throwing that much money on a full race trac bar setup...
if that dont help than pollyurethane inserts...
than go the full race trac bar setup
Old Feb 7, 2006 | 06:46 PM
Pee Wee's Avatar
Default Re: noone likes wheel hop ... (jaydeum4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeum4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">if its lowered i would start with a camber kit instead of throwing that much money on a full race trac bar setup...
you say it like its a waste of money seriously its a huge difference
Old Feb 7, 2006 | 06:52 PM
si0385.'s Avatar
its not a waste of money at all... im saving up for one right now... im also preping for turbo next summer and my 4-1 header hits right now...
stock motor and stock mounts i would start with camber kit and inserts
Old Feb 7, 2006 | 06:56 PM
Tyson's Avatar
https://honda-tech.com/zerothread?id=1124506
Old Feb 11, 2006 | 04:45 PM
fresh pizza guy's Avatar
$4500 in a D series
Default Re: noone likes wheel hop ... (Tyson)
so... i have a 2000 civic ex, with innovative full race mounts, tein SS damper kit, Skunk2 camber kit, nitto Neo Gen tires, and my turbo d16 still gets wheel hop... i suppose my only other option is traction bars, correct?
Old Feb 11, 2006 | 04:50 PM
Pee Wee's Avatar
Default Re: noone likes wheel hop ... (fresh pizza guy)
its not your only option but it does work.
Old Feb 11, 2006 | 04:53 PM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fresh pizza guy &raquo;</TD></TR><TR><TD CLASS="quote">so... i have a 2000 civic ex, with innovative full race mounts, tein SS damper kit, Skunk2 camber kit, nitto Neo Gen tires, and my turbo d16 still gets wheel hop... i suppose my only other option is traction bars, correct?</TD></TR></TABLE>
sounds like a nice setup... get it aligned again it can get nocked out from time to time... but full race trac bars are completley worth it with a setup like that imo
Old Feb 11, 2006 | 05:50 PM
fireant's Avatar
squirt some GE black silicone II caulk into the motor mounts, then clean up the mess with an ice cube. It works wonders for $6.
Old Feb 11, 2006 | 05:53 PM
si0385.'s Avatar
Default Re: noone likes wheel hop ... (fireant)
3m window weld works better thats made of urethane
Old Feb 12, 2006 | 06:48 AM
Mr Synister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">full-race traction bars </TD></TR></TABLE>
x2
I just ordered mine and cant wait for it to arrive.
EK FLY
Suspension & Brakes
May 14, 2006 07:47 AM
mekanism
Jun 27, 2005 07:07 PM
.Thomas
Mar 15, 2005 08:34 PM
DAredteg
Feb 28, 2004 12:04 PM
MasterCrx
Feb 6, 2004 08:05 AM
