need help what is this part called??? (dohc zc)
i need to know what the part that holds the oil filter is called!!! i was told it's an oil cooler?? also if anyone knows anything about it please share, i have an oil leak coming from behind it (it's not the filter) so i need to know if i need somekind of gasket or seal? and where can i get one (if needed) thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> i need to know what the part that holds the oil filter is called!!! i was told it's an oil cooler?? also if anyone knows anything about it please share, i have an oil leak coming from behind it (it's not the filter) so i need to know if i need somekind of gasket or seal? and where can i get one (if needed) thanks for any help
yes it is the oil cooler (note the coolant hoses routing through it), all you need is to put on the oil filter and your good to go.
</TD></TR></TABLE>yes it is the oil cooler (note the coolant hoses routing through it), all you need is to put on the oil filter and your good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC »</TD></TR><TR><TD CLASS="quote">i'm not sure man but your motor is lookin clean keep up work</TD></TR></TABLE>sorry thats not my motor, i just used the pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">
yes it is the oil cooler (note the coolant hoses routing through it), all you need is to put on the oil filter and your good to go.</TD></TR></TABLE>sorry but i think your wrong because i have a leak behind the cooler<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">it has an o-ring behind it
91316-PE7-730 O-RING (62.4X3.1) 1989 INTEGRA </TD></TR></TABLE>thanks again......man your the know it all for zc's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">yes it is the oil cooler (note the coolant hoses routing through it), all you need is to put on the oil filter and your good to go.</TD></TR></TABLE>sorry but i think your wrong because i have a leak behind the cooler<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">it has an o-ring behind it
yes - CRX Si also had some oil cooler, but part is no longer stocked by Honda - you need to get it from Acura - go here and enter part no.
http://www.acuraoemparts.com/delray/jsp/home.jsp
Well if you mentioned it was leaking then it would not have been hard to say, yes you need to replace the seal, way to forget that part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">Well if you mentioned it was leaking then it would not have been hard to say, yes you need to replace the seal, way to forget that part.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> i need to know what the part that holds the oil filter is called!!! i was told it's an oil cooler?? also if anyone knows anything about it please share, i have an oil leak coming from behind it (it's not the filter) so i need to know if i need somekind of gasket or seal? and where can i get one (if needed) thanks for any help </TD></TR></TABLE> yeah it sucks i forgot the part, it's all i need to drive the car out, and i cant find 1
puertoricanboy90
14
Mar 22, 2010 07:11 PM
