evap leak test detector??
Old Feb 7, 2006 | 11:00 AM
2fast2accord98's Avatar
Default evap leak test detector??
hey does any one know where to buy a evap leak detector? i did some search on yahoo and google and came up with detector that cost 1000 or more. im looking for a detector that is decent and doesnt cost too much. anyone? i need one that detects gas from evap not refrigerent gas that is used on a/c. thanks
Old Feb 7, 2006 | 11:10 AM
P_Adams's Avatar
Default Re: evap leak test detector?? (2fast2accord420)
You're not going to find one cheap. They are all Professional quality, and I've yet to see a consumer unit.
It would be cheaper to use the Florescent dye and a Black-light procedure, but you'd still see an outlay for tools you might use three times.....
P
Old Feb 7, 2006 | 11:40 AM
so how would i use the florescent dye and black light procedure? i would use that method as long as it doesnt mess up anything .
Old Feb 7, 2006 | 01:14 PM
P_Adams's Avatar
Default Re: (2fast2accord420)
The florescent dye is introduced into the refrigerant charge, the system is allowed to run (for perhaps a day or two) and then the blacklight is played over the a/c components. If there is a leak apparent it will glow either blue or yellow when the ultra-violet light hits it.
It washes off afterwards.
P
Old Feb 7, 2006 | 02:43 PM
YeuEmMaiMai's Avatar
Default Re: (P_Adams)
they got this new stuff that actually glows when it is exposed to air. It is green colored and you don't even need anything but a regular light to see it.
Old Feb 7, 2006 | 02:48 PM
Default Re: (YeuEmMaiMai)
and where would i get this stuff from and how much?
Old Feb 7, 2006 | 03:21 PM
I got it from a Dodge dealer for about $10
beastman@
Oct 15, 2007 09:19 PM
booost
Welding / Fabrication
12
Oct 10, 2007 04:30 AM
accorded66
Aug 5, 2005 08:11 PM
mikeyg
Aug 23, 2004 12:00 AM
turboex
Dec 29, 2003 11:41 PM
