swap hesistates no codes
Old Feb 7, 2006 | 10:25 AM
Turbo_Mike's Avatar
Default swap hesistates no codes
Just got my hatch running with a 2000 ls swap. Using obd2 harness and sensors, etc. Just plug and play, and using a obd1 p75.
The car is running extremely rough, wont accelerate, no power etc. Timing is good, fuel is good, spark is good.
Took the vc off and the cams are right on, dizzy is on...new cap, rotor, plugs..... plug wires are good...dont know where else to look??
Are all obd2 injectors the same... cause i'm using one ls injector and 3 hx injectors, i hope this issnt my problem :X
Modified by MIKE JONES at 5:00 PM 2/8/2006
Old Feb 7, 2006 | 11:20 AM
racer_X_123's Avatar
Default Re: swap hesistates no codes (MIKE JONES)
hey man, i had the same problem with my swap... i swaped out my D16Y7 for a 96 LS motor... we used the Y7 injectors... and to my surprise the motor would run like crap... changed out the injectors and solved the problem... if you took the injectors from a Y7 they are 190cc/min and all other D and B series motors use 240c/min. the Y7 is the only motor that used the smaller injectors
Old Feb 7, 2006 | 11:21 AM
Turbo_Mike's Avatar
Default Re: swap hesistates no codes (racer_X_123)
hx = y7 ??
Old Feb 7, 2006 | 06:45 PM
Turbo_Mike's Avatar
I guess my o2 is my problem: https://honda-tech.com/zero...age=1
Old Feb 8, 2006 | 10:53 AM
Turbo_Mike's Avatar
was better for about 10 minutes now its back to the same ****
Old Feb 11, 2006 | 06:37 PM
Turbo_Mike's Avatar
She is still running really rough at idle and while its cold. Once it is warmed up it revs through the powerband better and smoother, still is pretty choppy at idle though.
I'm dont have either torque mount in yet, so i dont know if that could be related?
Old Feb 13, 2006 | 03:59 AM
Turbo_Mike's Avatar
Old Feb 13, 2006 | 05:30 AM
Danronian's Avatar
I'd put all the same injectors in first. That could be your prob for sure.
Old Feb 13, 2006 | 07:53 AM
advert's Avatar
could your map and tps just be switched and its not throwing a code for some reason? or maybe your iacv and iat? those are all the same plugs and kinda in the same area. just a thot i doubt thats its but anything is worth a shot
Old Feb 13, 2006 | 02:22 PM
Turbo_Mike's Avatar
Default Re: (advert)
all the plugs are good
Old Feb 17, 2006 | 10:56 PM
Turbo_Mike's Avatar
Default Re: (MIKE JONES)
FINALLY SHE THREW A CODE TONIGHT, 43 - fuel system failure??
Such a generic code .... any suggestions?
Old Feb 17, 2006 | 10:58 PM
Naruto's Avatar
much like several have said....have you changed the fuel injectors?
Old Feb 17, 2006 | 11:03 PM
Turbo_Mike's Avatar
Default Re: (Naruto)
yes just put in a known workign set
Old Feb 17, 2006 | 11:22 PM
Naruto's Avatar
ok....
when you took the valve cover off, did you see a lot of crap in there? Like dirty ****? If so....try some "BG" after an oil change.
Old Feb 17, 2006 | 11:24 PM
Turbo_Mike's Avatar
nah, motor is clean as a whistle. Out of a 2000 ls, with like 42k on it
Old Feb 17, 2006 | 11:52 PM
ZipTieGUy's Avatar
sounds like aproblem with the dizzy
Old Feb 18, 2006 | 12:29 AM
shorto85's Avatar
Have you checked your fuel filter to make sure it wasn't clogged.
Old Feb 18, 2006 | 05:49 AM
Turbo_Mike's Avatar
Default Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">sounds like aproblem with the dizzy</TD></TR></TABLE>
why do u say this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked your fuel filter to make sure it wasn't clogged.</TD></TR></TABLE>
Fuel pressure looks good, and the car ran fine when it was stock
Old Feb 19, 2006 | 04:01 PM
Turbo_Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKE JONES &raquo;</TD></TR><TR><TD CLASS="quote">FINALLY SHE THREW A CODE TONIGHT, 43 - fuel system failure??
Such a generic code .... any suggestions? </TD></TR></TABLE>
reset the ecu and the code came back...so it wasnt a random one like most people get. Runs smoothe once the car is up to temp, so that sort of rules out a faulty o2 ...
Old Feb 20, 2006 | 09:54 AM
lojackgsr's Avatar
nm
Old Feb 20, 2006 | 12:36 PM
Turbo_Mike's Avatar
Default Re: (lojackgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lojackgsr &raquo;</TD></TR><TR><TD CLASS="quote">nm</TD></TR></TABLE>
gummer88
22
May 24, 2013 01:13 PM
Ek9Kiddo
Sep 5, 2010 12:04 PM
quick4thgen
Aug 30, 2007 04:33 AM
axtran
30
May 11, 2006 09:48 PM
Turbo_Mike
26
Feb 20, 2006 12:37 PM
