90 crx install dilemma
Old Feb 7, 2006 | 08:16 AM
VeilSide_Mas's Avatar
Default 90 crx install dilemma
I called on two shops to help me install my kyb agx , they told me the car uses struts for the front and it requires a special tool to remove and install it . is that true? i thought struts and shocks can be installed with just spring compressor and normal hand tools?
Old Feb 7, 2006 | 08:24 AM
Pee Wee's Avatar
Default Re: 90 crx install dilemma (VeilSide_Mas)
smack yourself for trying to pay someone to do the easiest job in the world.
14 nuts total. thats it. do it yourself
Old Feb 7, 2006 | 08:27 AM
bassofbob's Avatar
I did mine with out the spring compressor. I think the only tools I used to change everything was a socket wrench and a hex key. The torch, dremmel, drill, and reciprocating saw were used to get a stupid broken bolt out.
Old Feb 7, 2006 | 08:33 AM
yea i was goiing to do the job myself but i called jus tto check how much labor does it cost to let others do it. and its like $280 for all four , thats ridiculous man.
so i wont need to use any special tools to compress the strut for the front suspension?
i'm going to install some lowering springs with agx , guess i need to scavenge the shock mounts and bump stops from the stock suspension right?
Old Feb 7, 2006 | 08:42 AM
bassofbob's Avatar
Default Re: (VeilSide_Mas)
I used all of the old parts. I would probably get some new bump stops though because the stocks ones were not really designed for a low car (I think). Newer part will definately not hurt.
Old Feb 7, 2006 | 08:52 AM
rsca_crx's Avatar
Default Re: (bassofbob)
you've been around long enough to know how to answer all of your questions. it will take you less time to do it yourself than to bring it somewhere and get it done.
and any shop that tells you they have some difficulty with a shock istall shouldn't be allowed anywhere near anything you own.
Old Feb 7, 2006 | 01:58 PM
new bump stops are only available in the honda dealership or can i get them at some auto parts store? or at least where can i buy bump stops suited for lowered car from stores?
Modified by VeilSide_Mas at 5:18 PM 2/7/2006
S2000Forsale
Honda S2000
12
Oct 14, 2005 12:56 PM
Heath
12
Aug 2, 2005 07:31 PM
distortedfuture
36
Apr 2, 2004 09:30 AM
silverintegra9
Oct 8, 2002 12:28 PM
Isaac
Sep 25, 2001 02:58 PM
