wiring harnesses
i am putting a b16 into a crx. i have heard that it is common to re-use my old harness on my new motor. is it possible to use the harness that came with the new motor? especially since my came with the fuse box and everything. i hope i am being specific enough.
thankyou very much!
{edit} sorry about the poll! wrong button
[Modified by keebler65, 2:01 AM 3/26/2002]
thankyou very much!
No you can't reuse the harness that came with the motor. It's from a Right Hand Drive car and won't fit.
Just reuse your Si/HF (MPFI) harness and add the 4 wires needed for Vtec.
Here is the B16a1 pinouts:
http://www3.honda-perf.org/community...Trey/b16a1.htm
If you have a DX (DPFI) then you are in for a real treat........
Good Luck,
Good Luck,
i have another question then.......how do i know for sure if its right hand drive? does that mean that the wires come off of the engine from the left side? because on my new motor, they still come off of the motor from the right side (passenger). i guess i want to make sure that the motor that came today is truly the JDM and not the USDM motor.
thanks
thanks
dude go to http://www.hondata.com and use their guide for the pinouts of the pr3. it makes **** SO easy.
Chris_
Feb 23, 2002 07:10 PM
