Raising compression on a b16.
Old Feb 6, 2006 | 09:15 PM
Chief Wenceslaw's Avatar
Default Raising compression on a b16.
I want to raise my compression from a 10.2 to around 11.7:1. Could I get away with milling the head to gain the extra compression, or would it need some extra help? I want to try and do this as cheaply as possible.
Old Feb 6, 2006 | 10:07 PM
robotosan's Avatar
Default Re: Raising compression on a b16. (Chief Wenceslaw)
http://www.zealautowerks.com/index.html
find out for yourself.
Old Feb 6, 2006 | 10:51 PM
Default Re: Raising compression on a b16. (CRXhf_89)
Thanks! I did some searching before I posted, but I didn't find anything like that. That's incredible...
Old Feb 7, 2006 | 04:45 AM
StorminMatt's Avatar
Just keep in mind that if you increase compression through milling or a thinner head gasket, you bring the valves closer to the pistons, increasing the chances of a collision. This is a particular problem if you plan to run bigger cams and/or try to adjust timing away from stock with adjustable cam gears. So if you are increasing compression to run a bigger cam, keep this in mind.
Old Feb 7, 2006 | 06:30 AM
Pee Wee's Avatar
Default Re: Raising compression on a b16. (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXhf_89 &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.zealautowerks.com/index.html
find out for yourself.</TD></TR></TABLE>
that link is good stuff
Old Feb 7, 2006 | 11:55 AM
drSquish's Avatar
is that wrong or are only usdm pistons pr3s? because my "jdm" b16a is a pr3...
Old Feb 7, 2006 | 05:30 PM
Default Re: (drSquish)
Don't worry, no aftermarket cams here. I'm leaving everything stock, just looking to pick up a few horses relatively easy. My head gasket is bad anyways, so I figured why not. I think I'll go with a 2 layer head gasket, 1 layer would probobly run too hot. it also looks like I can only mill off .02 before I have a problem with piston clearance.
Old Feb 7, 2006 | 05:34 PM
mar778c's Avatar
Community Builder
Community Influencer
To mill your head enough to get 11.7 compression would mean removing the entire quench area. Even on stock cams, you would have a excellent chance of piston to valve contact.
Old Feb 7, 2006 | 05:59 PM
Default Re: Raising compression on a b16. (mar778c)
Don't worry, I alreaedy checked it out, and it looks like 11.2 is the best I'm going to be getting without doing something else, which is out of the question because I'm broke as a joke. That website really helped.
Mikes2000civicsi
Jan 22, 2007 12:37 PM
EG type GTR
Aug 13, 2006 09:05 AM
RobbieG35
Apr 28, 2004 06:28 PM
ITR_1211
Jan 18, 2004 08:09 AM
red91g2
Mar 3, 2003 12:12 PM
