center console
Old Feb 6, 2006 | 07:09 PM
vtecpower3088's Avatar
Default center console
Does anybody know how to take apart the center console for a 99 EX 5-speed. i need to install my short shift adapter. If anybody has detailed instructions or pictures that would be great. Thanx
Old Feb 6, 2006 | 08:18 PM
iam7head's Avatar
Default Re: center console (vtecpower3088)
no picture, so you just have to take my word for it.
pull out the cup holder section by pull it striaght up, there' no screw just some metal clips.
the rest of the shifter console is the same, pull up the ebrake, and pull the whole section out, again, there's only metal clips holding it down.
just in case you loose some of those metal clip, honda sells them for 25 cents each.
once you get it open, you can loose the boot hold down from the inside
Old Feb 6, 2006 | 09:45 PM
Heat's Avatar
Default Re: center console (iam7head)
http://www.handa-accessories.c...k.pdf
Look at Step 22, shows you where the clips are.
What does a short shift adapter do? Is it just a short shift ****? If so, please post a picture when you're done, I'm curious to see how it looks. I have a '99 LX 5-speed.
Old Feb 7, 2006 | 12:57 PM
Default Re: center console (Heat)
The short shift adapter reduces the throw by about 30%. I bought a Fidanza short shift adapter from Sport Compact Only. I had to modify the hole a little to make it bigger so the bolt would fit through and I had to get a 5/16 nut to secure the other bolt that was attached to the adapter. All in all it took me about 20 minutes and I can definitly tell the difference. I would recommend this to all drivers that have manuals. Great product for pretty cheap($30).
Old Feb 7, 2006 | 04:19 PM
Ruskimafia's Avatar
all i did was i took a hand saw and sawed down the shifter the way i liked it and it works Fine and it didnt cost a penny!!
Old Feb 7, 2006 | 05:42 PM
Default Re: (Ruskimafia)
I had mine sawed down too but the adapter makes it even shorter. I took it for an extensive, hard drive tonight and it did great. Even though cutting the stick makes the throw shorter, the adapter makes the likage to the lever shorter. I just did both.
Old Feb 7, 2006 | 11:31 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruskimafia &raquo;</TD></TR><TR><TD CLASS="quote">all i did was i took a hand saw and sawed down the shifter the way i liked it and it works Fine and it didnt cost a penny!!</TD></TR></TABLE>
a shorten shifter will not shorten your throw
Old Feb 8, 2006 | 12:22 AM
silver2000accord's Avatar
Default Re: (iam7head)
IM LOOKIN FOR A SHORT SHIFTER TOO...AND THIS IS WAT I'VE FOUND..LET ME KNOW WAT YOU GUYS THINK ABOUT IT... http://www.pspectuning.com/9802accord.php
Old Feb 8, 2006 | 12:28 PM
Default Re: (silver2000accord)
That one looks good. I just wish I had found it before i had the lever cut down. That one will be more expensive than cutting it but then you can keep your stock lever if you ever want to replace it.
Geo4k
Nov 29, 2011 04:55 PM
slowhitEJ1
Oct 30, 2008 11:15 AM
RedHondaSi
Mar 3, 2004 03:57 PM
jdmintegra1994
Nov 25, 2003 06:22 PM
SleepyR
Oct 6, 2001 06:21 PM
