Cheap hp
Old Mar 25, 2002 | 04:14 PM
CRXBoy's Avatar
Default Cheap hp
i want some really cheap ways to make horse poer out of my 89 crx dx thnx
Old Mar 25, 2002 | 04:29 PM
crxzc's Avatar
Default Re: Cheap hp (CRXBoy)
there is no cheap way to get horsepower. more horsepower=$$$$$$$
Old Mar 25, 2002 | 04:30 PM
rainforest's Avatar
oil catch can 12 dollars cools down intake temps.
thermo wrap from discount auto parts.
ingnition timing.
lighten it.
bolt off exhaust.
Old Mar 25, 2002 | 04:31 PM
Hcivic88's Avatar
thick racing stripes
well, what mods do u already have? the best way to start would be to look for deals on intakes, headers and exhaust. you may hear from people that removing or gutting your exhaust makes a big difference, but i highly do not recommend doing it. it all depends on how much $ you wanna start off spending
Old Mar 25, 2002 | 06:35 PM
89 CRX SI's Avatar
Default Re: Cheap hp (Hcivic88)
He has cold air and exhaust and some pollys and lowering stuff. HANDLES DOPE. 16" rims and tires etc. He wants to know ways on increasing power. Give him the instructions on changing your timing and how much.
Old Mar 25, 2002 | 06:41 PM
93delsol's Avatar
New User
get naaaws
Old Mar 25, 2002 | 07:21 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
convert to MPFI
Old Mar 25, 2002 | 07:27 PM
ViperRedCRX's Avatar
Default Re: Cheap hp (stock2theboneCRX)
convert to MPFI
i agree! that is the cheapest best mod you could do. and you can do it for around $100...the only time you'll get 10-15hp for that much
Old Mar 25, 2002 | 07:34 PM
maximedx's Avatar
Default Re: Cheap hp (d16crxdxr)
yes go with mpfi.i do this swap before i put my piston and etc .i have very surprising of the difference.go for it.
Old Mar 25, 2002 | 07:44 PM
89 CRX SI's Avatar
Default Re: Cheap hp (maximedx)
Then hes got to sell is CAI i guess he could sell it on here. Cause the MPFI is diff intake right? I got MPFI and my intake is diff. Mines an Si thats what you all mean with the MPFI right??????
THX keep em coming
Old Mar 25, 2002 | 09:20 PM
CRXBoy's Avatar
thanx guys this is a ******* awsome site thanx so much for the help
Old Mar 26, 2002 | 03:52 PM
89 CRX SI's Avatar
So can you use any Si intake manifold? 90 Civic Hatch Si work? What else will we need for the conversion? So far what i gather we need is :
89-91 CRX/Civic Si manifold says Programmed fuel... on it
All intake vacume hoses.
89-91 CRX/Civi Si throttle body
89-91 CRX/Civic Si ECU --> does it do anything
Anything else? Bolt on swap the ECU reset? Just manifold and tbody needed? Thx guys cause my buddy wants more HP
Old Mar 26, 2002 | 08:07 PM
89 CRX SI's Avatar
Default Re: Cheap hp (89 CRX SI)
Guys please tell us how to change to MPFI . What is needed. Going to wrecker tommorow want to know what to pull off an 90 Civic Hatch Si.
Thanks again guys
Old Mar 26, 2002 | 08:15 PM
88-91 distibutor, injectors, resistors, computer, manifold, head from the Si. Some other stuff maybe needed sorry about that. But your going to do some wiring. Hopefully this will help
Old Mar 26, 2002 | 08:18 PM
89 CRX SI's Avatar
You need to swap to an Si head???? He already has a SOHC 16v. What are the resistors and does the DX valve cover fit on a Si head if you have to swap heads. What engine is supposed to be in a DX?? What code i mean. And we need a d16a6 head????????
Old Mar 26, 2002 | 09:08 PM
Redline130's Avatar
You don't need to swap heads. You'll need the Si distributor, ecu, intake manifold, injectors, throttle body, throttle cable, and injector resistor. The injector resistor is located in the upper right hand corner of the engine compartment (if you were standing in front of the car). It's a small silver box with fins on it, and a green connector. The DX is a D15B2.
Old Mar 26, 2002 | 09:10 PM
89 CRX SI's Avatar
Default Re: Cheap hp (cyber13)
ThX so much cyber 13 well the civic Si hatch crashed and we will try and cut the firewall to pull the intake manifold off. Does it have to be a Si distro??? Cause that ones broken.
Again THX a lot
Old Mar 26, 2002 | 09:49 PM
Redline130's Avatar
Yeah, as much as possible, try to get an Si one, although an HF or a 90-91 Integra one would probably do as well. Make sure the intake manifold isn't damaged as well either.
Old Mar 26, 2002 | 10:45 PM
Cyber13, I know he really doesnt need the Si head, but it will be better because of the cam. Just my opinion
Old Mar 26, 2002 | 11:07 PM
jdmhondageek's Avatar
Add stickers.
10 HP each.
Old Mar 27, 2002 | 03:43 AM
bseriesrex's Avatar
Hey if you switch to mpfi then you should use the 88-89 integra ecu it has more agressive fuel maps and such.Also try soomewhere like Gude for a cam they are inexpensive and help out some.You could always get a zc for around $600-800.
Old Mar 27, 2002 | 07:09 AM
89 CRX SI's Avatar
Default Re: Cheap hp (bseriesrex)
Ok stickers are gay but will integra LS ECU be good? Is there any good way to see if manifold is bent in any way? Can the honda dealership get me the needed gaskets. What if we just poped the cam out of the Si and swaped it in the DX?? I guess what your ssaying is that the Si cam has a more agressive cut right? Alright well THX so much guys and well keep you updateed on what shaking.
Old Mar 27, 2002 | 07:10 AM
89 CRX SI's Avatar
Default Re: Cheap hp (beatdown88hf)
And we prefer cheap NA way? ie. no NOS Turbo or SC
THX again
Old Mar 27, 2002 | 07:19 AM
Cryptopsy's Avatar
Stupid question...but whats MPFI? Please excuse my ignorance.
Old Mar 27, 2002 | 07:30 AM
CRXBoy's Avatar
MPFI is Multy Port Fuel Injection ha no prob i didnt konw neither i had to find out to
