just did compression test, is these number correct?
Old Feb 6, 2006 | 06:22 PM
vietdragontekx's Avatar
Default just did compression test, is these number correct?
i have a 93 jdm h22a with a compression test of 200,200, 200,200 all across is that a good number?
Old Feb 6, 2006 | 06:24 PM
SteveoBA8's Avatar
Default Re: just did compression test, is these number correct? (vietdragontekx)
All the sprak plugs out? Did you hold it at WOT during cranking?
Looks good, i got 220,221,223,220 on my jdm h22 and forgot to hold the throttle Wide open during cranking. id say your just fine, retest in a couple months and see
Old Feb 6, 2006 | 06:37 PM
Layziejoe775's Avatar
Default Re: just did compression test, is these number correct? (SteveoBA8)
what if one didn't hold open the throttle body, and get 190 175 190 175...bad or concerned?
Old Feb 6, 2006 | 08:54 PM
i hold it at wide open throttle.
Old Feb 6, 2006 | 09:11 PM
roller3804's Avatar
the numbers are all consistent. its good
Old Feb 7, 2006 | 04:44 AM
Buffalo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 jdm h22a with a compression test of 200,200, 200,200 all across is that a good number?</TD></TR></TABLE>
whaaaaa? all 200? thats what i cal a perfect break in motor...
Old Feb 7, 2006 | 07:40 AM
EK9-Stealth's Avatar
240 all across for me...
Old Feb 7, 2006 | 07:22 PM
Default Re: (EK9-Stealth)
i think i got a 200 instead of higher because i need a valve adjustment.
xd69
Mar 7, 2006 12:10 PM
crazi_E
Jan 9, 2005 06:35 AM
ozzyman
Apr 22, 2004 10:12 AM
nos_b16
May 2, 2003 08:24 AM
