Auto to Manual Swap
From: With my POS D15B2, Whereever whenever, United States
Just wondering if this swap is hard as it seems.
I did it to a hatch, and it was pretty straight forward.
Not the prelude is cable, can someone enlighten me how much harder it is?
thanks
thanks
https://honda-tech.com/zerothread?id=1431069 here ya go, the swap is not that difficult. The hardest thing is running the oem pre-bend clutch hard line from the clutch master cylinder to the dampner assembly.( if you choose this option)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote">The hardest thing is running the oem pre-bend clutch hard line from the clutch master cylinder to the dampner assembly.( if you choose this option) </TD></TR></TABLE>
that was a PITA for me. I just made a new one that runs along top of the firewall.
It is really straight forward. I did it along with the motor swap, and I think it only took me 2-3 hours longer than the usual motor swap. There is a really good PDF write up floating around here somewhere. I will try to find it. Good luck man.
Here ya go.... Skrewdlude gave me this link a while back... still haven't done it yet.
http://www.superhonda.com/foru...90678
