CV Halfshaft issue...
Old Feb 6, 2006 | 04:06 PM
Wayne_Curr's Avatar
Default CV Halfshaft issue...
I searched and couldn't find anything in this forum. Today driving into work it sounds like my halfshaft is going out, dont know which one though. How do I tell which one is going out? Its clicking pretty bad when accelerating and braking, not when coasting though. Only makes noise when I'm putting torsion on it. Any help would be appreciated.
Old Feb 6, 2006 | 04:37 PM
Sam92Teg's Avatar
Default Re: CV Halfshaft issue... (Wayne_Curr)
search axle, not halfshaft
If it clicks while turning left it usually is your right axle and vise-versa.
Old Feb 7, 2006 | 10:58 AM
Wayne_Curr's Avatar
Default Re: CV Halfshaft issue... (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">search axle, not halfshaft
If it clicks while turning left it usually is your right axle and vise-versa.</TD></TR></TABLE>
Searched through all the axle threads and didn't find much...the thing is that it does it under acceleration and braking aside from turning. Could it be something more than the halfshaft? It seems that its just begining to be serious so i'm just gonna replace both axles this weekend. Anything else it could be?
Old Feb 7, 2006 | 11:15 AM
M Coop's Avatar
OK, FYI halfshaft is the one inbetween the drivers side axle and the trans. What you're looking for is either going to be called the axle or CV shaft. As for determining which one, I'd start by looking to see if either one has a torn boot and has sprayed grease all around it (if so that'd be my first suspect and if it hasn't gone bad it will soon) otherwise, drive your car and then have a friend drive the car with you in the passenger seat, you can usually tell which side it's coming from, the noise or vibration should be considerably more pronounced on one side. Not really likely to be anything but a bad CV from the way you've described it.
Old Feb 7, 2006 | 11:29 AM
Wayne_Curr's Avatar
Default Re: CV Halfshaft issue... (M Coop)
Alright awesome. I have a weekend without the girl so i'll crank out the axle replacements and hopfully there wont be any problems. Haven't personally done this before but I need to and i'll have a friend standing by who has
howangseg
Oct 13, 2006 11:54 AM
WillsH22Accord
Oct 23, 2004 07:37 AM
95GSRTT
Aug 4, 2004 10:01 PM
arren123
Apr 13, 2003 12:54 PM
